1923 radiola
1/24/2007 1:42:06 PMMaurice Gendreau
Working on radiola 2 and 3A and need values of capacitors in tuning circuit and source for obtaining replacements and resistive value of grid leak resistor.
1/24/2007 3:32:36 PMDoug Criner
A III-A has the same RF ckt as the III. Values of fixed tuning caps and grid leak here:
http://www.nostalgiaair.org/PagesByModel/349/M0040349.pdf
http://www.nostalgiaair.org/PagesByModel/350/M0040350.pdf
:Working on radiola 2 and 3A and need values of capacitors in tuning circuit and source for obtaining replacements and resistive value of grid leak resistor.
1/24/2007 3:33:05 PMDoug Criner
1/24/2007 3:34:03 PMDoug Criner
PS, are you sure the tuning caps are bad? they see virtually no voltage.
:A III-A has the same RF ckt as the III. Values of fixed tuning caps and grid leak here:
:http://www.nostalgiaair.org/PagesByModel/349/M0040349.pdf
:http://www.nostalgiaair.org/PagesByModel/350/M0040350.pdf
::Working on radiola 2 and 3A and need values of capacitors in tuning circuit and source for obtaining replacements and resistive value of grid leak resistor.
