Dial Cord Schematic for Zenith 7H820
1/19/2007 11:24:25 PMBob Elbert
Is there a place on line to get this information?
Or can someone send me this info if they have it
please, THanks bobelbert at hotmail dot com
1/19/2007 11:31:38 PMJoe Wutsch
Yes, there is a place and here is the link for you.
http://www.theoldradiofixerupperguy.com/dial%20cord.html
1/19/2007 11:42:00 PMBob Elbert
:Yes, there is a place and here is the link for you.
:http://www.theoldradiofixerupperguy.com/dial%20cord.html
Thanks for that link but the ZH820 is not listed but I may have found one similar. I wil see if it works.
Bob
1/20/2007 12:46:23 AMJoe Wutsch
::Yes, there is a place and here is the link for you.
::http://www.theoldradiofixerupperguy.com/dial%20cord.html
:Thanks for that link but the ZH820 is not listed but I may have found one similar. I wil see if it works.
:Bob
It just might be close enough
1/20/2007 1:11:45 AMB9b Elbert
:::Yes, there is a place and here is the link for you.
:::http://www.theoldradiofixerupperguy.com/dial%20cord.html
::Thanks for that link but the ZH820 is not listed but I may have found one similar. I wil see if it works.
::Bob
:It just might be close enough
It is finished and all put back together. Really sounds great. Thanks for your reference.
Bob
2/20/2007 4:00:57 PMROB
:Is there a place on line to get this information?
:Or can someone send me this info if they have it
:please, THanks bobelbert at hotmail dot com
2/20/2007 7:08:29 PMEdd
In case there was still any degree of uncertainity on the referencing....plus filling in for
Rob....here's the real thing.
There is the conventional tuning knob to the tuning condensers drum lash-up. Then there is the the separate stringing of that drum over to the like drum that drives the dial pointer.
With my degrees of refinement of technique, I now use a clear / milky teflon tube around the dual grooved center post. Then initially, use a loose length of dial cord... garotte style... to form two like, slight inward grooves in that tubing. The result is one minumal degree of cord friction and one resulting smooth, easy dial transverse.
Prior to that technique, I was using a coat of thick Z-5 silicone grease on the cord only for the
distance that it moved past that post. The silicone not being affected by sag from tube heat .
And,since that dial string up was separate from the main basic dial drive, no cross contamination
ever ocurred.
That set is the grand daddy of a series of later units that were first class DX performers..having a
RF stage as well as dual IF's in its design, that larger center speaker, also giving a good sound to it.
Your referencing to " Dial Cords Is Us " is:
http://img153.imageshack.us/img153/3570/zenithh820dialcordrestrxy1.jpg
