silvertone
1/14/2007 5:32:30 PMbud
I have discovered a beautifull chairside Silvertone.
Mid l930's. no model number. medal tag indicated Hazeltine 833, SN 49388. three band, 4 knobs, tube types: 80, 6V6, 75,and 6A7. can you help with a model number and schematic? Thanks
1/14/2007 6:42:35 PMDoug Criner
Bud, Stein's console guide has 15 pages for Silvertone, with about 16 radios pictured per page. If you can post a photo of your set on one of the freebie sites, and link it here, I can probably find you set.
None of the Silvertone consoles listed by Stein
have just 4 tubes.
The numbers you provided don't tie into any of my listings.
:I have discovered a beautifull chairside Silvertone.
:Mid l930's. no model number. medal tag indicated Hazeltine 833, SN 49388. three band, 4 knobs, tube types: 80, 6V6, 75,and 6A7. can you help with a model number and schematic? Thanks
1/14/2007 6:47:09 PMDoug Criner
I'm sorry, you said it was a chairside. Chairsides don't show up in Stein's guide. Still, if you post a photo, maybe somebody will be able to identify it.
:Bud, Stein's console guide has 15 pages for Silvertone, with about 16 radios pictured per page. If you can post a photo of your set on one of the freebie sites, and link it here, I can probably find you set.
:None of the Silvertone consoles listed by Stein
:have just 4 tubes.
:The numbers you provided don't tie into any of my listings.
::I have discovered a beautifull chairside Silvertone.
::Mid l930's. no model number. medal tag indicated Hazeltine 833, SN 49388. three band, 4 knobs, tube types: 80, 6V6, 75,and 6A7. can you help with a model number and schematic? Thanks
1/15/2007 10:33:45 AMbud
:have just 4 tubes.
Sorry to miss led you. it is a five tube set with two type 75 tubes, 80, 6v6, 6a7. dial face and papper tag indicates Silvertone. Bud
1/15/2007 7:44:32 PMrghines1
Was not able to find that tube lineup in the MYE Radio Encyclopedia. Perhaps different substitutions were used for the 6V6 and the first 75 tube? But that opens up a lot of permutations.
Richard
1/17/2007 12:32:50 PMbud
:Was not able to find that tube lineup in the MYE Radio Encyclopedia. Perhaps different substitutions were used for the 6V6 and the first 75 tube? But that opens up a lot of permutations.
:Richard
after a lot of searching thru my reference book I came up with what I hope the the correct tube arrangement for Silvertone "chairside. they are: 6A7, 78, 75, 6V6 and type 80. from this can you give me a model number? Thanks, Bud
1/19/2007 3:49:30 PMrghines1
Bud,
Looked in MYE book again and having trouble with the 6V6 tube in the lineup. Only saw the 6V6 listed twice in different lineups. The 78 tube doesn't show up in any close lineup. The 6D6 does come up the most and is a interchangable with a 78. Seems the mostly lineup is 6A7, 6D6, 75, 42, 80. Therefore the following models are suggested.
1939
1957
4466, 4467, 4469
7150
7171
7184
Richard
1/17/2007 10:13:20 PMCarl C
Try this link - there are over 300 pictures of Silvertone radios with Model Numbers.
http://antiqueradios.com/gallery/
1/18/2007 12:47:39 PMbud
: Try this link - there are over 300 pictures of Silvertone radios with Model Numbers.
: http://antiqueradios.com/gallery/
anitqueradios.com is a great site. Thanks. but no joy on my chairside model.
