Mark,
I think you got me on the right track. It now receives on strong stations but can only hear it on full volume. It also kicks out a braker if I connect a ground. I guess I have some more work ahead. Thanks for the help.
P.J.
http://www.nostalgiaair.org/PagesByModel/823/M0012823.pdf
The above is your schematic. Notice, too, how the choke is between the line cord and the chassis. When you were attempting to ground the chassis, you could have also blown this choke!
The electrolytics (two of them) should have their positives connected to the cathode of the 25Z5. The negative of the larger one should go to the line cord side of the choke. The negative of the smaller one should go to the radio side of the choke.
PJ, the reason you are blowing the breaker sometimes when you go to ground the set is that your chassis is attached to one side of the AC (power) line. Without a polarized plug on the set at times you have a live chassis and other times you have a negative chassis, depending on how the two prongs are inserted in the outlet. Suggest you mark the plug and always make sure the chassis prong goes to ground (if outlets wired correctly thats the left slot facing the outlet on the three prong outlets). On the older outlets it should be the same but the fixture could be wired correctly but installed upside down since there is no third prong to orient it correctly. On those outlets determine the ground side with a voltmeter and mark it for future use. Remember that chassis can be live 120VAC if you don't observe the grounding proceedure. PL
