:For you who are new to my problem I am starting a new string. I found the capacitor that blew, it was the 8mf 450 cap. It was the replacement for original can cap that has a paper ring on the top and bottom of the can. When I replaced the new cap under the chassis I hooked the ground to the old ground, which is actually grounded to the can, but not to the chassis. They have a paper ring that does not let the can ground to the chassis. The mystery whie resistor in question when measured read 23600 ohms, so it is not the 9000 ohms resistor as thought earlier. So now I am very confused. It was recomended that I look at the second type schematic, but mine is not a phono model. I think mine is more like the first schematic. It looks like the resistor is #57 23500 ohms on the schematic and the cap is #56 that blew and does not actually have a negative ground and go to the transformer tap #4. OK, that said, all looks right on my chassis....WHAT WENT WRONG!!!!!!
:Thanks
:David
:I think I found the problem. Those pesky negative-filtered power supplies. I read your article and wonder if I am not actually getting a ground to the chassis when it is supposed to be floating ground. The one can that I was telling you about had the cardboard sleeve and that is the capacitor that I replaced and blew. I connected it to the lead that it was hooked up to before, it looks like it is comeing from the can, but probally is tied to the chassis, or the paper is not working as a good insulator any more. The positive of that cap goes to white resistor 25000 ohms, speaker and 80 rectifier the neagative goes to the isolated can and the wire wound multi tap resistor. That is how I have it up.
:Thanks
:David
:Hello, I tried your ideas and still keep blowing that 8mf cap. I tried another sinario of my own and still blew another 8 mf cap. What am I missing?
:Thanks
:David
:Thanks
:David
David: Take out the caps you put in, take a break from the set (you must have some project on hold) then go back and, using the schematic only, wire in the caps with out using any of the old cap terminals. You may have to add a one or two contact terminal strip to the chassis (your in the area of the xfermr mtg bolts and the cap bakelite box mtg screws)for connection points. pl
:Thats a great idea. I will work on it this weekend and give you an update.
:David
: OK David, you going to drop the other shoe or what? PL
::Thats a great idea. I will work on it this weekend and give you an update.
::David
