Thanks again for all of your time !
Steve
Thanks !
Steve
:After hearing of your final evaluaton of direct phono input right into the p[oint that AM radio info would be injected, looks like you are up into either the location of a phono cartridge with yet higher output level or the addition of a phono preamp stage as I mentioned previously. That could be of either tube or solid state design. Also concur on "x"s comment as per the actual presence of a mute switch on your current TT in the unit, since the current TT was not original to the unit. BUT I would have not expected an AMPLIFIED output of much more than the normal chatter noise from a needle riding within a record groove, should that mute switch been closed.
:The info that would be nice is to know now is actually what cartridge brand, and its number, that you have currently mounted in the tone arm, such that research can be made of its actual P/P output specs.
-Steve
:Ed,
: On there currently is an astatic 10-66.
:Thanks !
: Steve
::After hearing of your final evaluaton of direct phono input right into the p[oint that AM radio info would be injected, looks like you are up into either the location of a phono cartridge with yet higher output level or the addition of a phono preamp stage as I mentioned previously. That could be of either tube or solid state design. Also concur on "x"s comment as per the actual presence of a mute switch on your current TT in the unit, since the current TT was not original to the unit. BUT I would have not expected an AMPLIFIED output of much more than the normal chatter noise from a needle riding within a record groove, should that mute switch been closed.
::The info that would be nice is to know now is actually what cartridge brand, and its number, that you have currently mounted in the tone arm, such that research can be made of its actual P/P output specs.
::73's de Edd
:Ed,
:Thanks !
: Steve
::73's de Edd
