David
The Paco is a basic emission tester and uses the tube under test to rectify the AC current, the tubes are tested as rectifiers. The rectifier in your tester is only used for the leakage/shorts test and the line adjust function, it is not used for the emission test. The easiest way to fix the resistors is to parallel them with another resistor to bring them back to the proper value.
