I will have to look tonight when I get home but I should have an OBS Tube setup chart for this tester. This should be what you are looking for.
Tom Guest
: I have an Eico 625 Tube tester with the roll chart. I also have some Philco radios with tubes
: that are not listed, such as 41, 7A7, 7B7, 7C6, and 7C7. Is there an available chart that lists
: the settings for these tube types? Thanks. -Roy
41:---33--6.3--3--2,3,4,--5,6.
7a7:---29---6.3----2---3,4----7,8.
7b7;---28---6.3---- 2---2,3,6---4,7,8.
7c6;--34----6.3----1--2,3,6--4,7,8
7c7;---12---6.3----1---2,3,6--4,7,8
: Hello Roy
: I will have to look tonight when I get home but I should have an OBS Tube setup chart for this tester. This should be what you are looking for.
: Tom Guest
: : I have an Eico 625 Tube tester with the roll chart. I also have some Philco radios with tubes
: : that are not listed, such as 41, 7A7, 7B7, 7C6, and 7C7. Is there an available chart that lists
: : the settings for these tube types? Thanks. -Roy
No problem,, a few tube settings on my chart are missing as it had a small section missing when i bought it..
it's hard to find one in good shape..
i had intended to make a copy and somehow find a suitable length of paper or paste sections run out of my printer...
Big project!..may be awhile before i get around to it..i have a tv7/du and the 625 was just a pet project..
Have any idea if yours reads correctly of not.?..
this one seems to read low, although it's linear and at least i can tell if a tube is a problem/not a problem with it quickly on the bench without dragging out the TV7, which takes up too much space..
E mail me if you need any more settings...
check www.manualman, he might have one for sale.
Anyone experienced in troubleshooting these old tester have any idea what I can
do next? Is there any calibration type procedure that Eico
had on other testers that could apply and help pinpoint a problem area?
Thanks for any help
Rick
