I see a Model 5-R listed in Slusser's guide, which matches your description, more or less. I don't find a schematic.
This is undoubtedly a tuned-radio-freq set. Nothing complicated since most TRFs are more alike than different, but probably not a good set to start on if it's your first, particularly w/o a schematic.
:Found this 20's chasis (looks in excellent shape), says Official Browning Drake Kit Set on black front face plate with 2 dials plus 3 knobs. Chasis has 5 tubes, all 01A. It has 6 connectors for battery, 2 for antenna and 2 for headphones.4 tubes test 75% or better, one is bad. Before I pay $42 for a new 01A, can anyone tell me more about this radio? (schematic, model, how to operate/restore)any tip would be greatly appreciated. Thanks.
:Norbert, don't pay $42 for a new '01A. Shop around for a used one for $10-12.
:I see a Model 5-R listed in Slusser's guide, which matches your description, more or less. I don't find a schematic.
:This is undoubtedly a tuned-radio-freq set. Nothing complicated since most TRFs are more alike than different, but probably not a good set to start on if it's your first, particularly w/o a schematic.
::Found this 20's chasis (looks in excellent shape), says Official Browning Drake Kit Set on black front face plate with 2 dials plus 3 knobs. Chasis has 5 tubes, all 01A. It has 6 connectors for battery, 2 for antenna and 2 for headphones.4 tubes test 75% or better, one is bad. Before I pay $42 for a new 01A, can anyone tell me more about this radio? (schematic, model, how to operate/restore)any tip would be greatly appreciated. Thanks.
Check the battery eliminator to see if it's working. Does it not have an A voltage (5V)? Which hook ups are you unsure of? Post a listing of what you think goes where, and we can check it.
When you say that the tubular glass resistors are OK, do you now have a schematic that tells you for sure what the values should be? These have usually drifted up out of sight.
Check the audio interstage xfmrs, primary and secondaries. They are often open.
:I hear you Doug, it's hard to resist though, because it's really in great shape and the circuitry seems fairly simple. I worked on a lot of 40's/50's stuff, this is my first 20's and I think to give it a try and buy a used 01A. I checked the 5 funny looking resistors (look like glas fuses) and only one needs to be replaced. On the 5 caps - they are flat, rectangular, metal. Should i replace them all? Now on the power connection: The radio came with a seperate, original Transformer ( Webster Full Wave)instead of a battery, which has 4 outlets: B-, Det., B+90 and Power. The radio has 3 sets of 2 inlets: B Det.+/ B Amp+, +A Bat-/ A Bat+, C Bat-/ C Bat+ . To be sure, what connects to what? Thanks for the help.
::Norbert, don't pay $42 for a new '01A. Shop around for a used one for $10-12.
::I see a Model 5-R listed in Slusser's guide, which matches your description, more or less. I don't find a schematic.
::This is undoubtedly a tuned-radio-freq set. Nothing complicated since most TRFs are more alike than different, but probably not a good set to start on if it's your first, particularly w/o a schematic.
:::Found this 20's chasis (looks in excellent shape), says Official Browning Drake Kit Set on black front face plate with 2 dials plus 3 knobs. Chasis has 5 tubes, all 01A. It has 6 connectors for battery, 2 for antenna and 2 for headphones.4 tubes test 75% or better, one is bad. Before I pay $42 for a new 01A, can anyone tell me more about this radio? (schematic, model, how to operate/restore)any tip would be greatly appreciated. Thanks.
This is a 5-tube battery-powered TRF, correct? You say that there are five of the glass, tubular resistors in the radio? I would have expected there to be only one, the detector grid-leak resistor.
:The caps you describe are micas. I would leave them alone. They are almost always OK.
:Check the battery eliminator to see if it's working. Does it not have an A voltage (5V)? Which hook ups are you unsure of? Post a listing of what you think goes where, and we can check it.
:When you say that the tubular glass resistors are OK, do you now have a schematic that tells you for sure what the values should be? These have usually drifted up out of sight.
:Check the audio interstage xfmrs, primary and secondaries. They are often open.
::I hear you Doug, it's hard to resist though, because it's really in great shape and the circuitry seems fairly simple. I worked on a lot of 40's/50's stuff, this is my first 20's and I think to give it a try and buy a used 01A. I checked the 5 funny looking resistors (look like glas fuses) and only one needs to be replaced. On the 5 caps - they are flat, rectangular, metal. Should i replace them all? Now on the power connection: The radio came with a seperate, original Transformer ( Webster Full Wave)instead of a battery, which has 4 outlets: B-, Det., B+90 and Power. The radio has 3 sets of 2 inlets: B Det.+/ B Amp+, +A Bat-/ A Bat+, C Bat-/ C Bat+ . To be sure, what connects to what? Thanks for the help.
:::Norbert, don't pay $42 for a new '01A. Shop around for a used one for $10-12.
:::I see a Model 5-R listed in Slusser's guide, which matches your description, more or less. I don't find a schematic.
:::This is undoubtedly a tuned-radio-freq set. Nothing complicated since most TRFs are more alike than different, but probably not a good set to start on if it's your first, particularly w/o a schematic.
::::Found this 20's chasis (looks in excellent shape), says Official Browning Drake Kit Set on black front face plate with 2 dials plus 3 knobs. Chasis has 5 tubes, all 01A. It has 6 connectors for battery, 2 for antenna and 2 for headphones.4 tubes test 75% or better, one is bad. Before I pay $42 for a new 01A, can anyone tell me more about this radio? (schematic, model, how to operate/restore)any tip would be greatly appreciated. Thanks.
The Webster thingy sounds like a "B eliminator" or B+ power supply. It is incredibly unlikely that it will work without replacement of the filter capacitors. You'd be better off using another power source at first, so you have less to go wrong and think about.
:Norbert, one more thing puzzles me slightly (but w/o a schematic, we're kind of shooting in the dark here).
:This is a 5-tube battery-powered TRF, correct? You say that there are five of the glass, tubular resistors in the radio? I would have expected there to be only one, the detector grid-leak resistor.
::The caps you describe are micas. I would leave them alone. They are almost always OK.
::Check the battery eliminator to see if it's working. Does it not have an A voltage (5V)? Which hook ups are you unsure of? Post a listing of what you think goes where, and we can check it.
::When you say that the tubular glass resistors are OK, do you now have a schematic that tells you for sure what the values should be? These have usually drifted up out of sight.
::Check the audio interstage xfmrs, primary and secondaries. They are often open.
:::I hear you Doug, it's hard to resist though, because it's really in great shape and the circuitry seems fairly simple. I worked on a lot of 40's/50's stuff, this is my first 20's and I think to give it a try and buy a used 01A. I checked the 5 funny looking resistors (look like glas fuses) and only one needs to be replaced. On the 5 caps - they are flat, rectangular, metal. Should i replace them all? Now on the power connection: The radio came with a seperate, original Transformer ( Webster Full Wave)instead of a battery, which has 4 outlets: B-, Det., B+90 and Power. The radio has 3 sets of 2 inlets: B Det.+/ B Amp+, +A Bat-/ A Bat+, C Bat-/ C Bat+ . To be sure, what connects to what? Thanks for the help.
::::Norbert, don't pay $42 for a new '01A. Shop around for a used one for $10-12.
::::I see a Model 5-R listed in Slusser's guide, which matches your description, more or less. I don't find a schematic.
::::This is undoubtedly a tuned-radio-freq set. Nothing complicated since most TRFs are more alike than different, but probably not a good set to start on if it's your first, particularly w/o a schematic.
:::::Found this 20's chasis (looks in excellent shape), says Official Browning Drake Kit Set on black front face plate with 2 dials plus 3 knobs. Chasis has 5 tubes, all 01A. It has 6 connectors for battery, 2 for antenna and 2 for headphones.4 tubes test 75% or better, one is bad. Before I pay $42 for a new 01A, can anyone tell me more about this radio? (schematic, model, how to operate/restore)any tip would be greatly appreciated. Thanks.
Bill VA
:I forgot to mention that Browning-Drakes work extremely well and are a lot of fun to use, once you get the hang of the controls. Your set probably dates from 1926.
