Atwater knob removable
1/1/2007 10:11:58 PMRobert Matteson
How do you remove the tuner knob on a Atwater 44? I removed the set screws on the knob but it is stuck to the shaft.
1/2/2007 6:37:47 AMJon
:How do you remove the tuner knob on a Atwater 44? I removed the set screws on the knob but it is stuck to the shaft.
Try dropping a few drops of a good penetrating oil down the set screw hole. Let it sit for a while. Some gentle taps on the knob can help break it from the shaft.
Jon.
1/2/2007 8:05:55 AMRobert Matteson
I tried that and it worked, thanks. Was really frozen on that shaft.
1/2/2007 8:20:54 PMdan livesay
:I tried that and it worked, thanks. Was really frozen on that shaft.
Hi Bob
Below the large tuning knob is a small knob for fine tuning. It has to be removed before the main tuning knob can be removed.There ie a screw in the end of the small knob.
