Don
Hi Don check out www.the radiofixerupperguy, for the dial stringing guide , as far as the noise be sure the bearings on the tuner are clean and greased usually the little metal plate that provides tension at the end of the tuner will cause noise if dirty
E.
http://www.theoldradiofixerupperguy.com/dial%20cord.html
If the rotor plates are not shorting against the fixed plates of the tuning cap around 600 or 700, check the spring contact (bronse?) between the two sections (or three) of the tuning cap and make sure it is clean. This makes contact between the rotor and fixed parts of the cap. If this is dirty, it can cause static when tuning.
:Hello again all! Just completed recapping RCA model 85-t and I have to admit, it sounds pretty good. I just have two problems now, i have no dial cord or belt in it, have to tune from inside by hand. I can't find any dial cord stringing diagrams anywhere, dont even know if this takes a belt or string. Anyone know where i can get a diagram of this? Also, i checked all the plates on tuning caps, nothing sticking,bent, etc.. but i have a lot of static/scratching between 600-700 on the dial. Any ideas what else to look for? It finally feels good to have a project at least partially operating, since I'm a newbie and I have 2 other projects that are still DOA (sigh..) Any help would be greatly appreciated!
:Don
:Don,
:If the rotor plates are not shorting against the fixed plates of the tuning cap around 600 or 700, check the spring contact (bronse?) between the two sections (or three) of the tuning cap and make sure it is clean. This makes contact between the rotor and fixed parts of the cap. If this is dirty, it can cause static when tuning.
:Radiodoc
::Hello again all! Just completed recapping RCA model 85-t and I have to admit, it sounds pretty good. I just have two problems now, i have no dial cord or belt in it, have to tune from inside by hand. I can't find any dial cord stringing diagrams anywhere, dont even know if this takes a belt or string. Anyone know where i can get a diagram of this? Also, i checked all the plates on tuning caps, nothing sticking,bent, etc.. but i have a lot of static/scratching between 600-700 on the dial. Any ideas what else to look for? It finally feels good to have a project at least partially operating, since I'm a newbie and I have 2 other projects that are still DOA (sigh..) Any help would be greatly appreciated!
::Don
Thanks Alex! You can send it to dklempka@stny.rr.com
I really appreciate it!
Don
Good luck, Alex
