The secondary has a center-tapped winding for your push-pull output.
Maybe you can disassemble your xfmr, and replace the coil, preserving the original look. Consider Part# HX124C $11.41.
:Hi, I need to replace the AF transformer in a model 124 crosley, how do I figure out the replacement size?
RadioDaze Part# HX124A $13.26.
:The secondary has a center-tapped winding for your push-pull output.
:Maybe you can disassemble your xfmr, and replace the coil, preserving the original look. Consider Part# HX124C $11.41.
::Hi, I need to replace the AF transformer in a model 124 crosley, how do I figure out the replacement size?
