____________________________________________________________________
:My son and I are trying to resurrect a Zenith 8-S-154 radio from 1938, our first attempt at an old radio. We've replaced all the tubes. There get no sound from the speaker, but we get a signal from the speaker socket with an oscilloscope. How can we test the speaker? Is there any way we can connect a modern speaker to the signal current? Thanks.
:____________________________________________________________________
::My son and I are trying to resurrect a Zenith 8-S-154 radio from 1938, our first attempt at an old radio. We've replaced all the tubes. There get no sound from the speaker, but we get a signal from the speaker socket with an oscilloscope. How can we test the speaker? Is there any way we can connect a modern speaker to the signal current? Thanks.
What's called for, in my opinion, is a systematic troubleshooting approach, which is very difficult and laborious to walk somebody through via the internet. Otherwise, you will likely be shooting in the dark, spending unnecessary money in replacing perfectly good parts, and possibly making a mess of things.
If this is your first radio to repair, you'd be best to get some hands-on help. Or, set this Zenith aside, read some books, and start with a 5-tube, AC/DC, post-war radio.
:Unfortunately the tubes are usually good and one of the last things to go bad. The radio will need some major restoration before it is powered up. The electrolytics will have to be replaced, the capacitors have to be checked and replaced (I always replace all of them) The resistors should be checked and replaced as necessary, the wiring needs to be checked. As you can see it is not just a simple matter to get one of these going but failure to do these steps can cause some serious component damage. Of course you could always fire it up the way it is using a variac or a dim bulb tester and hope for the best. If you feel you are competent enough to tackle this job the fellows on this forum would be glad to help you.
:Dave
