Come on guys, put your rabbit ears on and see if there are some answers for these questions. Thanks
My tube tester, for what it is worth (it is an emissions tester), now tests tubes that seem to work fairly well as weak or good, depending on the condition of the tube. My #2 setting was particularily at fault. Tubes always tested at weak or replace, so I strongly suspected that its resistors might be drifted. Now it's as good as the other settings (of course you must use the proper setting for the tube in question).
The resistors in my tester are gold band resistors. It isn't like my tester is supposed to be accurate (again, it's an emissions tester), but it is probably a good idea to replace with gold band resistors.
Carl, thank you, I'll a;so try that
Tom:
Thanks for the answer, I'll try it and see.
