You will have a problem with adding FM.. FM is used on higher frequencies and has a different method of detection. I will send you a schematic of an AC/DC radio with AM and FM.
: i am looking for a schematic i can down load. i am trying to add fm capability to my hallicrafters s-40a but most info is for am. if schematic came w/ brief explanation of operation it would be greatly appreciated thanks
: Dan
: You will have a problem with adding FM.. FM is used on higher frequencies and has a different method of detection. I will send you a schematic of an AC/DC radio with AM and FM.
: Norm
: : i am looking for a schematic i can down load. i am trying to add fm capability to my hallicrafters s-40a but most info is for am. if schematic came w/ brief explanation of operation it would be greatly appreciated thanks
: : Dan
: : You will have a problem with adding FM.. FM is used on higher frequencies and has a different method of detection. I will send you a schematic of an AC/DC radio with AM and FM.
: : Norm
: : : i am looking for a schematic i can down load. i am trying to add fm capability to my hallicrafters s-40a but most info is for am. if schematic came w/ brief explanation of operation it would be greatly appreciated thanks
: : : Dan
: : : You will have a problem with adding FM.. FM is used on higher frequencies and has a different method of detection. I will send you a schematic of an AC/DC radio with AM and FM.
: : : Norm
: : : : i am looking for a schematic i can down load. i am trying to add fm capability to my hallicrafters s-40a but most info is for am. if schematic came w/ brief explanation of operation it would be greatly appreciated thanks
thanks norm, don, for the assistance and the schematic.i have heard it will be difficult to add fm but so far the hardest part has been to make the time to get started. i'll keep you posted on progress (and probably ask for more help) as this project gets off the ground. dan.
