Got the phico 624 workin'but have a hum
12/17/2006 10:38:42 AMblackbird
Well gang I got my philco 624 working! I replaced the power caps in the radio section, checked the other caps in the b unit section, put a couple drops of water in the bias cells, the hooked 'er up to a small 6v lead acid cell and she sprang to life! I can get all the am stations here! Good volume too! But I have a hum.... like if you are humming the letter m.
Any ideas?
Also a second question...There was in the b unit, crumbled yellow stuff in there like a sheild of some sort, is it a sheild for that choke (xfmr) in the b unit?
12/17/2006 11:36:45 AMNorm Leal
Hi
Philco 624 uses a vibrator. The vibrator will cause some hum that can't be eliminated.
Be sure that buffer cap 49, .01 mf, has been replaced.
http://www.nostalgiaair.org/PagesByModel/809/M0013809.pdf
These radios did use extra filtering. Chokes 51 and 53 along with caps are filters. Some wires might be shielded? Philco used rubber coated wire that deterioriates in time.
:Well gang I got my philco 624 working! I replaced the power caps in the radio section, checked the other caps in the b unit section, put a couple drops of water in the bias cells, the hooked 'er up to a small 6v lead acid cell and she sprang to life! I can get all the am stations here! Good volume too! But I have a hum.... like if you are humming the letter m.
:Any ideas?
: Also a second question...There was in the b unit, crumbled yellow stuff in there like a sheild of some sort, is it a sheild for that choke (xfmr) in the b unit?
