A lot of radios hum faintly, though, depending on the type of hum, it could be power supply hum (somewhat normal) or hum due to poor shielding in the audio section.
You must follow the schematic perfectly. Make sure that everything is wired exactly the same way as in the schematic (electrically, not physically). Maybe, too, a wire is broken. If you hooked something to a filament lead instead of the chassis, this would make things hum loudly. Lots of possibilities.
Again, go through everything and make sure that you connected all of the new components and wires properly.
Not all circuits are the same, and so not all radios can be altered in this way. Some radios actually use the speaker's wiring in some of the switches. I had a chassis from a 1951 consol that put a choke in series with the speaker's voice coil for one of the settings. I forgot which it was.
:I noticed that my tone controls dont work on my Zenith 8s463. When I select one on the tone buttons the radio hums bad. Also then I touch any of the wires going to the controls it hums really loud.
The normal switch in most cases connects a condenser to the plate of the 1st audio tube. It does this when pulled out, and makes the audio very plain.
As Elton said, you can push in or pull out whatever levers you want. It's all up to your taste. I found that the best sound was obtained when the Normal and Speech buttons were left in, and the rest were pulled out. In radios where the Treble button enhances harsh highs (speech), and the Speech button enhances the highest register, then it sounds best with the Speech out and the Treble in.
