:Has anyone created a list or site for transistors or circuits to replace tubes?
But I think most amplifier and detector tubes would take dozens of transistors and passive components to make up a one-to-one replacement that could be plugged into a tube socket. To start with, a tube's plate and grid voltages are way off from what typical solid-state circuits need to see, biasing is different, and performance is quite different.
If I were going to try, my first choice would be to use an A-D converter on the tube's grid input, send the digitized signal to a microprocessor programmed to simulate the tube's performance, and then a D-A for the output. Also, need a regulated power supply that perhaps could be derived from the filament ckt? Not sure how to interface the output to the plate ckt.
I'm not aware of a "list or site" on this subject.
:Just wondering, why would you want to do that when most tubes are easy to come by?
::Has anyone created a list or site for transistors or circuits to replace tubes?
:The real old tubes are getting super hard to find and even though some claim to be NOS I have had some bad ones. Even some that have tested good on my testers are no good when in the set.
