Do a search on Speaker Cones. There have been discussions recently with cones selling for less than a dollar. Might search forums on antiqueradios.com .
:Does anyone know who sells vintage paper speaker cones? I thought I saw a place on the internet years ago that sold the paper cones and told how to go about installing them.
James
Go to electronix.com they sell most cones under $1.00
Wayne
Mechanical support.
Wires from the voice coil coming from the _top_ of the voice coil will run about 10mm on the cone surface, be glued to the cone then soldered to small rivets. The "flexible" wiring will then be soldered under the paper cone. That way, if for some reasons you pull on the wire, the voice coil will have less chances to get damaged.
On some older speakers, the voice coil wiring is directly attached to the speaker wires then to end connectors or soldering tabs.
Z-
