Your radio is Canadian. There are some schematics for Phonola here:
http://www.nostalgiaair.org/Resources/498/T0000498.htm
:I'm on the search for some schematics for a Dominion Electrohome (Phonola) "Rambler". The only radio on the net is being recon by John Rose, and so far he only has a picture.
Wondering if you ever found a schematic for the radio. I'm in the same situation - no luck so far !
Cheers
Paul
paulsmi55@gmail.com
:Hi Trent
: Your radio is Canadian. There are some schematics for Phonola here:
:http://www.nostalgiaair.org/Resources/498/T0000498.htm
::I'm on the search for some schematics for a Dominion Electrohome (Phonola) "Rambler". The only radio on the net is being recon by John Rose, and so far he only has a picture.
:Hi
:Wondering if you ever found a schematic for the radio. I'm in the same situation - no luck so far !
:Cheers
:Paul
:paulsmi55@gmail.com
::Hi Trent
:: Your radio is Canadian. There are some schematics for Phonola here:
::http://www.nostalgiaair.org/Resources/498/T0000498.htm
:::I'm on the search for some schematics for a Dominion Electrohome (Phonola) "Rambler". The only radio on the net is being recon by John Rose, and so far he only has a picture.
:I'll have a look through my stuff - but Grandpa's radio shop in Kitchener,Ontario will likely have the factory info on it - look him up - ask for George Found - you could also check with Justradios.
:Steve
::Hi
::Wondering if you ever found a schematic for the radio. I'm in the same situation - no luck so far !
::Cheers
::Paul
::paulsmi55@gmail.com
:::Hi Trent
::: Your radio is Canadian. There are some schematics for Phonola here:
:::http://www.nostalgiaair.org/Resources/498/T0000498.htm
::::I'm on the search for some schematics for a Dominion Electrohome (Phonola) "Rambler". The only radio on the net is being recon by John Rose, and so far he only has a picture.
