The set originally had one 80 mfd cap and three 40 mfd electrolytics. These were replaced with one 100 mfd @ 160V and three 47 mfd @ 160V caps. Can someone please explain what could he going on?
Thanks again,
Larry Rickard
New capacitors on the B+ line should not have caused the problem. Could an electrolytic cap be connected to a signal line? The output transformer has a tap. Is the electrolytic connected to the proper terminal?
You could reduce the value of coupling caps which will cut back on bass. Your radio has a .02 mfd to the grid of the output. It could be reduced to .005 mfd or less.
: I've just recapped a Zenith H725. I replaced all of the paper caps, then turned the set on to test it out. It sounded fine. After I replaced all four electrolytics, the set had so much bass response that it distorted the treble and sounded garbled. I can only get a clean sound with the volume control turned almost all the way down.
: The set originally had one 80 mfd cap and three 40 mfd electrolytics. These were replaced with one 100 mfd @ 160V and three 47 mfd @ 160V caps. Can someone please explain what could he going on?
: Thanks again,
: Larry Rickard
