http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=001&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=110052313957&rd=1&rd=1
and there are no identifying marks as to model number.
I has tubes numbered: 12SA7 12SK7 12SQ7 35Z5 50L6
Can anyone tell me the model number, or if the
circuit is "very" standard, what schematic I could
use to approximate this circuit's setup. Also if
these turntables run on 117VAC so that I could test the
motor with the full AC power..
:Hi, I got this on ebay:
:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=001&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=110052313957&rd=1&rd=1
:and there are no identifying marks as to model number.
:I has tubes numbered: 12SA7 12SK7 12SQ7 35Z5 50L6
:Can anyone tell me the model number, or if the
:circuit is "very" standard, what schematic I could
:use to approximate this circuit's setup. Also if
:these turntables run on 117VAC so that I could test the
:motor with the full AC power..
:Thanks
http://radioatticarchives.com/images/e/Emerson_FJ412_Bardos.jpg
But that's not listed on this site in resources. I can probably easily find a similar tube lineup schematic though.
The knobs are exactly alike, fit on grooved posts and have a crossbar to fit the slit on the end of the shaft. Is there a name for this know style? Thanks.
:Thanks, actually that is a popular line up as you say. I did play with the unit, looks like a late 30's. I got the AM to work great, with little or no hum, all original parts. The motor works fine too, just had a bad SPST switch to turn it on. The cartridge may be bad (Astatic 612 M122), I get a noise from touching the solder contacts, but not from scratching the needle, so I guess its plugged into the chassis correctly.
:Before I first posted, I managed to find an Emerson Radio which most closely resembles it by looks, the FJ412
:http://radioatticarchives.com/images/e/Emerson_FJ412_Bardos.jpg
:But that's not listed on this site in resources. I can probably easily find a similar tube lineup schematic though.
:The knobs are exactly alike, fit on grooved posts and have a crossbar to fit the slit on the end of the shaft. Is there a name for this know style? Thanks.
I've been trying the past few hours and have not been able to locate any such numbers on any site, antique radio and others. It's 78 RPM only, and the unit is from around 1942. It does say "crystal pickup" on the scehmatic.
Any help appreciated.
:I'm having trouble with exactly the same thing.
:Not sure if the cartridge is good. The needle looks ok but does not tighten into the cartridge with the set screws. The wiring seems ok, but I get no "amp" sound when tapping on it, just a bit of soft static when actually touching the connecting wires.
:On the cartridge it says "The Astatic Corp, Conneaut, Ohio" licensed under Brush Development patents, with a series of numbers, and patented in Canada 1931.
:There are two numbers stamped in red over this:
:612
:M22
:I've been trying the past few hours and have not been able to locate any such numbers on any site, antique radio and others. It's 78 RPM only, and the unit is from around 1942. It does say "crystal pickup" on the scehmatic.
:Any help appreciated.
:Well, post back if you find a solution, or can suggest a new cartridge unit that should definitely work as a substitute. I don't know whether or not in those days there were a lot of electrical differences in the cartridges
Piezo elements don't work.
>I've been led to believe that the ceramic parts are >nearly eqivalent to the old crystal parts as for >output level.
Send me a photo of your cartridge, I'll tell you what model it is.
Ceramic elements are NOT compatible to rebuild crystal cartridges. I offer a full How-To on my website if you are curious. See http://www.oldradioz.com/forum . Go in Z-Forum and private section, look for the full 8 parts tutorial including sound clips from different stylii.
Z-
:Piezo elements don't work.
:>I've been led to believe that the ceramic parts are >nearly eqivalent to the old crystal parts as for >output level.
:Send me a photo of your cartridge, I'll tell you what model it is.
:Ceramic elements are NOT compatible to rebuild crystal cartridges. I offer a full How-To on my website if you are curious. See http://www.oldradioz.com/forum . Go in Z-Forum and private section, look for the full 8 parts tutorial including sound clips from different stylii.
:Z-
Try: restoration at oldradioz dot com
Z-
