Are the two mercury batteries wired in series to give 2.4V? For example, lithiums put out 3V which might be OK, but you can come up with other voltages with various combinations of button cells. If you have room, you could put two or more in parallel for longer life? You'd need a battery holder, of course.
:I have a Zenith Royal 20 transistor radio, it needs 2 1.2 volt mercury batteries the part # is Z-640, does anyone know if I can locate them or suggest a subtitute, these batteries are small so I can't even put in 2 AAA's. Ralph Schneider
You may want to consider Nicad or Nimh rechargeable batteries. I beleive these put out 1.2V each
::I have a Zenith Royal 20 transistor radio, it needs 2 1.2 volt mercury batteries the part # is Z-640, does anyone know if I can locate them or suggest a subtitute, these batteries are small so I can't even put in 2 AAA's. Ralph Schneider
