Airline 2704 Console
11/19/2006 9:41:59 PMDonald
I just completly rebuild this radio. All caps new tubes some resistors and audio output transformer. I aligned it by the book. Playes good the only problem I have is if the dial is at the 1300 to 1450 range it is correct. With the dial at 1590 it recieves as station af 1630, dial at 920 station 820, dial at 810 station 660, and dial at 690 picks up a station 1420. Can anyone give me any hints of what to look for.
11/19/2006 11:54:13 PMThomas Dermody
Your IF transformers might be off....probably due to inaccuracies in your signal generator. Norm Leal has the answers to this problem.
Something else that helps is having a digital radio with a long wave band. This allows you to check your generator against a known base.
