Thanks for any help,
Mike Landon
Tubes for both the AK20 and the Radiola 17 are readily available, so why not just use tubes?
:Transistorized Radio - I just purchased 2 radios (AK 20 & RCA Radiola 17) at an auction that has some 4 pin tube bases in them with transistors. I would appreciate the circuit spec's for making transistorized tubes so that I can finish the job and make these radio's play.
:Thanks for any help,
:Mike Landon
Mike
:Michael: Sometimes I run across a recifier tube that's been replaced with a socket and a couple of diodes. Could this be what you're seeing? Those don't require any changes to the radio's basic circuitry (although they can be hard on the other tubes because of the hard start).
:Tubes for both the AK20 and the Radiola 17 are readily available, so why not just use tubes?
::Transistorized Radio - I just purchased 2 radios (AK 20 & RCA Radiola 17) at an auction that has some 4 pin tube bases in them with transistors. I would appreciate the circuit spec's for making transistorized tubes so that I can finish the job and make these radio's play.
::Thanks for any help,
::Mike Landon
Mike
::Mike Landon
Mike
::Mike Landon
_______________________________________________________
:Mike Landon
