I realize this is a bit off Radio topic...I hope no one objects.. but Maybe.... one of you who are more familiar with TV can enlighten me.
I know that the signal from the TV antenna is RF.... right? ...but how about the signal from cable?
Isn't that RF too?... or is it not?
Can it be fed into the same input "ANT" as the regular antenna input?... I thought it could... but apparently... I'm wrong.
When a TV says it is "cable ready" ... what does that mean?
I always thought it was just a separate 75 ohm coax connector path in parallel with the normal 300ohm twin lead ... going to the tuner.
You see...
I just bought a little (8" flat screen head-rest monitor/TV.
http://www.pyleaudio.com/itemdetail.asp?model=PLVWT8M
It says it works as a regular TV and has a TV tuner.
So...
I wanted it just to use as a regular TV. I want to keep it on my night table by my bed and set it on TV channel 3. Then feed it video via the output (chan 3 frequency) from my cable box.
But the antenna signal input jack that says "ANT" is a tip/ring type little jack.
Now this thing came with an adaptor that adapts from that small tip/ring jack to a coax cable.
So I figured I'd just put my cable box output coax into that.
But the first problem was that my coax wouldn't quite fit this adaptor because it was European sized.
So.. I had to go get the right sized adaptor at Radio Shack.
Then when I tried it it had very crappy snowy picture.
I called the NYC Pyle distributer and described that all I wanted to do was feed it video on channel 3 from my cable.
They said that perhaps it might have bad tuner and so I sent it in for repair.
BUT...They just sent it right back saying I cannot feed my coax signal into the Antenna input !!!
The return note they sent said:
"The Antenna is for RF only"... ("not digital cable signal")
So that sort of makes me feel stupid because I never tought that the cable signal for channel 3 was not the same as the RF signal for channel 3.
What is it then if not RF?
Anyway to achieve my intent..I ultimately have decided to just run the AV signal from the yellow RCA video-output jack on the cable box into the RCA yellow video-in port on the TV-monitor. ... and this works fine...
But why isn't this "cable ready"... and what is the cable signal if not RF?
:Let me try to toss this out to the the rest of you fellas...
:I realize this is a bit off Radio topic...I hope no one objects.. but Maybe.... one of you who are more familiar with TV can enlighten me.
:I know that the signal from the TV antenna is RF.... right? ...but how about the signal from cable?
:Isn't that RF too?... or is it not?
:Can it be fed into the same input "ANT" as the regular antenna input?... I thought it could... but apparently... I'm wrong.
:When a TV says it is "cable ready" ... what does that mean?
:I always thought it was just a separate 75 ohm coax connector path in parallel with the normal 300ohm twin lead ... going to the tuner.
:You see...
:I just bought a little (8" flat screen head-rest monitor/TV.
:http://www.pyleaudio.com/itemdetail.asp?model=PLVWT8M
:It says it works as a regular TV and has a TV tuner.
:So...
:I wanted it just to use as a regular TV. I want to keep it on my night table by my bed and set it on TV channel 3. Then feed it video via the output (chan 3 frequency) from my cable box.
:But the antenna signal input jack that says "ANT" is a tip/ring type little jack.
:Now this thing came with an adaptor that adapts from that small tip/ring jack to a coax cable.
:So I figured I'd just put my cable box output coax into that.
: But the first problem was that my coax wouldn't quite fit this adaptor because it was European sized.
:So.. I had to go get the right sized adaptor at Radio Shack.
:Then when I tried it it had very crappy snowy picture.
:I called the NYC Pyle distributer and described that all I wanted to do was feed it video on channel 3 from my cable.
:They said that perhaps it might have bad tuner and so I sent it in for repair.
:BUT...They just sent it right back saying I cannot feed my coax signal into the Antenna input !!!
:The return note they sent said:
:"The Antenna is for RF only"... ("not digital cable signal")
:So that sort of makes me feel stupid because I never tought that the cable signal for channel 3 was not the same as the RF signal for channel 3.
:What is it then if not RF?
:Anyway to achieve my intent..I ultimately have decided to just run the AV signal from the yellow RCA video-output jack on the cable box into the RCA yellow video-in port on the TV-monitor. ... and this works fine...
:But why isn't this "cable ready"... and what is the cable signal if not RF?
The cable box always had a choice for putting out on chan 3 or 4 which ever is otherwise not broadcast in your local area.
That's because (I thought) since the cable channels were mostly new additional programing channels above the standard broadcast (2-13)
now they also include chan 2-13
but I tgink in the early days around here you could still use your antenna for the loacal 2-13 broadcast but if chan 3 was not broadcast in your area you could use that to get the rest from the cable box.
But in any case... it was fed in via channel 3 or 4 which are in the same standard TV rf range no?
Also, if this is a foreign television that you are dealing with, perhaps the tuner is not well matched to our channel 3. The output from your cable box, which you feed into the RF of any other television, is RF, however.
Try feeding a regular antenna into that RF jack and see how well that thing tunes in stations.
David S.
:thanks.. ok.. this just all confirms my thinking... I am better pepared now on Monday to chat with the tech-guy that sent it back with tha note.
Now as far as the cable signal delivered to the house... it is both analog and digital...
up till last week.. I used to just directly connect it to both my two TVs with no cable box at all and eveything (all 78 channels) was "analog" .
But recently, to add certain channels that I wanted which were in the "digital group" ....they delivered and added one "digital" converter cable box to one of my TVs... just last week.
(However if I bypass that "digital" converter box and go directly in...to the main TV I stll get all 78 analog channels.)
Now..The ouput of that box is channel 3 regular RF.... and feeds into the regular VHF ANT input on the main TV..... I just split that and passed it along also to this other new 8" TV and that is where the signal is all snowy.
Here's the nub of my Question:
The thing I am tring to get clear about is... If I DO use the cable Box and I take the output signal (channel 3) and I can connect that into the VHF input and get clear and perfect reception into my other two TV's .... why CAN'T I also get a good clear picture when I connect that same (chan 3) signal into the ANT input of this PLVWT8M Pyle 8" TV/monitor?
Jim
Now I just got off the phone with the Technician who sent the set back telling me it was "meant for regular antenna, not digital cable"... he appologized for his error and admits that if I am using chan 3 out of my cable box that this should work fine. So he agreed to pull another unit from stock and test it then call me back... and if it works fine they will swap it out.
So ... "news at eleven".
But at this point the issue is not paramount as I have since already decided to use the AV RCA video cable instead which does work just fine.
