Battery-powered TRFs typically have connections for an external high-impedance speaker. Most of these sets (seems like virtually all manufacturers) label the two speaker connections as: + and -. Why? What difference does in make?
Speakers of the same vintage usually do not have polarity markings, so the radio's connections wouldn't be possible to follow anyway.
I understand the necessity for stereo speaker pairs to be matched, polarity-wise. But this was long before stereo.
On some of these old high impedance speakers polarity matters. There is DC going through the speaker as well as the AC signal. DC can pull the cone or diaphram so far as to make contact. It has to float for loudest and least distorted sound.
Best to use a choke from output tube to B+. Then cap couple plate to the speaker. This way no DC goes through your speaker.
:Here is something that has puzzled me.
:Battery-powered TRFs typically have connections for an external high-impedance speaker. Most of these sets (seems like virtually all manufacturers) label the two speaker connections as: + and -. Why? What difference does in make?
:Speakers of the same vintage usually do not have polarity markings, so the radio's connections wouldn't be possible to follow anyway.
:I understand the necessity for stereo speaker pairs to be matched, polarity-wise. But this was long before stereo.
This is interesting. Can you give me an example of a TRF with speaker polarity markings? I would like to look at the schematic.
Gary
Gary
This is pretty much a garden-variety TRF - with five '01A triode tubes and three tuning dials. The speaker terminals are marked positive and negative (on both the set itself and on the schematic).
Norm's explanation makes sense to me. However, none of my high-impedance speakers seem to have polarity markings.
:Doug:
:This is interesting. Can you give me an example of a TRF with speaker polarity markings? I would like to look at the schematic.
:Gary
::Here is something that has puzzled me.
::Battery-powered TRFs typically have connections for an external high-impedance speaker. Most of these sets (seems like virtually all manufacturers) label the two speaker connections as: + and -. Why? What difference does in make?
::Speakers of the same vintage usually do not have polarity markings, so the radio's connections wouldn't be possible to follow anyway.
::I understand the necessity for stereo speaker pairs to be matched, polarity-wise. But this was long before stereo.
The flexible wire used on old speakers sometimes has one lead striped. This was to indicate polarity. I had a few speakers lock up when connected in reverse. One was a cone type from around 1928 by Columbia.
:Gary, take a look, for example, at the schematic for a Stewart-Warner Model 300, c. 1925:
: http://www.nostalgiaair.org/PagesByModel/794/M0029794.pdf
:This is pretty much a garden-variety TRF - with five '01A triode tubes and three tuning dials. The speaker terminals are marked positive and negative (on both the set itself and on the schematic).
:Norm's explanation makes sense to me. However, none of my high-impedance speakers seem to have polarity markings.
::Doug:
::This is interesting. Can you give me an example of a TRF with speaker polarity markings? I would like to look at the schematic.
::Gary
:::Here is something that has puzzled me.
:::Battery-powered TRFs typically have connections for an external high-impedance speaker. Most of these sets (seems like virtually all manufacturers) label the two speaker connections as: + and -. Why? What difference does in make?
:::Speakers of the same vintage usually do not have polarity markings, so the radio's connections wouldn't be possible to follow anyway.
:::I understand the necessity for stereo speaker pairs to be matched, polarity-wise. But this was long before stereo.
