Can you tune in the oscillator signal on a portable transistor radio set next to the Philco? Should be at broadcast freq + IF. Once you have it, then wait for the Philco to conk out, and see if the oscillator is still running.
:Need some suggestions, earier I posted for a 2 meg volume , but I found one in my junk box and modified it to fit , it worked great , but now another problem as poped up. the radio acts as if the oscillator section is intermittent, sometimes if you turn it on it works great , other times nothing , even if I put a finger on the grid of the oscilator or the RF all I get is static and no stations on all bands and very low voulme, I tried a couple different 6A8's I had lying around and it would work a while and thought it was the tube but then the next time I turn it on it quit again, voltages seem to be with-in the norms even while not operating?? I have not changed a couple of the paper caps in the tuner as they are buried along with the coils up in the sub-assembly, I can't even check these relibly without a major tear down,I know most of you will tell me I have no choice but to tear into it, but I was hoping I might be missing something obvious . Has anyone ever delt with these sub-assembly tuners I do not even know how to begin to start if I have to tear into this,it appears the coils are riveted into place? I checked Chucks Site for any tips on this but none sound to promising as it says I will come up with new four letter words while trying to service it. plain and simple it acts like the oscilator tube just stops working??? any thoughts or ideas are appreciated before I am forced into possibly wreaking this trying to service it, this was not one of Philco's better ideas!!!
:Thanks
:Elton
Hi Elton,
From your descrption I would take a hard look at tube sockets. It seems lately I am running into more bad tube sockets than bad tubes. Octal tube sockes are usually quite reliable, but you can get bad ones even in ocatal.
Probably the best way to check is to wiggle the RF and converter tubes and see if you can control the frequency of cut out or to look for distortions on the sockets on the RF and converter tubes. Since the problem is intermittant ohmic tests will work only intermitantly.
If you find a bad connecting pin on a socket, replacing the socket would be nice, but the socket is probably as inaccessable as those capacitors. Recently I had this problem and soldered a wire to the tube pin which was failing contact. I now have to remember never to put that tube in a tube tester, but the radio works fine now.
I also noticed the many switches in htis radio's front end. I expect that they have been sprayed with tuner tonic.
Best Regards,
Bill Grimm
MRO
:Thanks
:Elton
