9/24/1997 1:13:49 PMtony deprato(44:0)
i am in need of 3 or 4 dial pointers that will work on slide rule type dials. or a source to buy new or used ones. i also need a glass dial plate for a hallicrafters 5r100a or 5r10a receiver.
i am also needing knobs for the following units
hallicrafters. S-38 series black and gray both also brass insert rings for band spread and main tuning knobs. knobs for G.E. mod. G-76 radiogrande console. knobs for S-94 and 5R100A . telescoping antenna's for the following units. hallicrafters S-120 and Zenith B-600 TransOceanic.
thanks for reading this. also will buy used units Want to buy hallicrafters " DEFENDER" table top am & sw radio. tony wa4jqs
3/20/2003 9:24:48 PMDarnell Little(20771:44)
:i am in need of 3 or 4 dial pointers that will work on slide rule type dials. or a source to buy new or used ones. i also need a glass dial plate for a hallicrafters 5r100a or 5r10a receiver.
:i am also needing knobs for the following units
:hallicrafters. S-38 series black and gray both also brass insert rings for band spread and main tuning knobs. knobs for G.E. mod. G-76 radiogrande console. knobs for S-94 and 5R100A . telescoping antenna's for the following units. hallicrafters S-120 and Zenith B-600 TransOceanic.
:thanks for reading this. also will buy used units Want to buy hallicrafters " DEFENDER" table top am & sw radio. tony wa4jqs
