Could the cap actually be a resistor made by micamold? Some of their resistors has 3 dots.
See no need for a mica capacitor at this location but a cathode resistor is needed. How does the center tap of your transformer high voltage winding return to chassis, ground?
:Have a problem with a schematic vs. actual. Radio is untouched original but there is a difference in one part of the schematic vs. chassis. I dont have R18,(280ohm 1.5watt resistor), that connects between pin 8 of 6F6 and, C20 electrolytic cap coming off the 6X5. Instead, there is a 24000pf mica there. Any ideas? Here is the schematic link:
:http://www.nostalgiaair.org/Resources/333/M0025333.htm
Dave,
I betcha if you measure across it you'll find some resistance, or maybe not if it is open.
