http://www.nostalgiaair.org/PagesByModel/101/M0025101.pdf
I had set my sig generator to 455khz and checked it with my frequency counter and set it to 455khz nearly exactly.
.. then with 400hz audio modulating the 455khz IF signal from the generator..I tweaked away on the trimmers..( just a touch here and there) and all seemed to be playing quite nicely.
BTW..(as recommended...I always peak the 2nd IF first then peak the first last)
Afterwards...however...I realized that these lousy old brittle/cracking crumblng darned rubber wires were in very sore need of replacing ....so I pulled the IF cans to redo the wires.
I did them one at a time ...so I rewired the 2nd IF first and returned it to the radio to test and it works nicely.
.... but later while I still had the other one (1st IF) out laying on the bench...I was kinda curious to see just how well the IFs really were tweaked.
( The Thomas Edison element of my psyche rearing it's ugly head again)
So I thought I'd check it using my scope.
So with no audio modulation...and without changing my signal generator frequency (455khz @ about 50mv pp output level)
... I just connected it directly to the primary input of the IF transformer. Blu & Red wires.
(btw... I also tried it coupled via a .1uf cap and there was no difference either way)
Then I put my scope on the output or 2ndary side (Green & black )and adjusted the scope's vertical input sensitivity down to the appropriate range... about 20mv per/box.
Here comes Question #1:
Well the output was very low... so I started tweaking the 2ndary trimmer cap and wow.... up popped the signal strong and large about 80 mv pp.
(wow!!... I even got about 30mv gain there too... wonder why that is too?? )
But so...Then I wondered why I had to re-tweak it so far to see the signal come up so nice and strong.
... esp because it seemed to be peaked quite nicely while in the radio.
So that's question #1.
Now question #2:
..is why is it that as I watched the 2ndary signal w/my scope... why is it that I can tweak all I want on the primary trimmer cap and yet see absolutely no gain or loss on the 2ndary signal?? You'd think that as I de-tuned the primary there'd be some fall off observed on the 2ndary.
Unless I'm just over-driving the hell out of the primary or something and swamping it to death with a 50mv input signal.
So I then I tried reversing the arrangement and fed the sig gen into the 2ndary side and then put the scope on the primary side... and re-tweaked the primary trimmer...then the signal came up on that side nicely too.. also to about 80mv pp. Why does this happen that way?
Now Question #3:
So now I can see an optimized 80 mv signal on both sides... but does that mean it is now more perfectly tuned then it was in the radio?
Well...I'll be able to tell best of course after I return it to the circuit to see how it operates.... but this certainly seems a little odd on the surface.
Especially curious about why tweaking the primary doesn't show effects on the 2ndary... kind of weird. No?
Using The previous direct connect method..I'm sure the signal gen is loading down the side it was connected to swamping it out.
If these aren't perfect after I return it to the radio.. maybe it's because these tank-circuit IFs ....while connected to the tubes are being affected both capacitively and inductively by the associated circuit elements... no?
So... ostensibly they'd be tuned perfectly... AND it seems in fact it is.
I had left the radio tuned to local station at 930kc.
And after replacing the IF and turning it back on, ...that station came in just about perfectly. After a minute warm up I just slightly rocked the tuner a bit to make sure the signal was maxed... and it just needed the slightest touch and I could hear the audio getting a bit better and then max itself. So I felt I was right on the station as far as my ears could tell.
( now 930kc + 455kc = 1385kc right?)
So I put my frequency generator probe close to the local oscillator coil just to see... and..There it was right smack dab on 1385kc!!! ( so it seems that after perfectly tweaking the IF outside the radio... the associated circuit elemnents when back in the radio had no additional loading effect on the IF transformer at all!)
Nice.
MRO
Don't connect the signal generator or scope probe to an IF Transformer. Both will add capacity and change alignment. Measure AVC voltage for the most accurate alignment. You could do this with a scope set on DC input.
:Try sleaving the brittle wires with shrink tubing. Sweep generators are more often used in FM or TV alignment where the combined frequency response is more critical. In FM & TV you are dealing with a much broader bandwidth than with AM. In AM just a signal generator and a scope or multimeter usually suffice just fine. In general the lowest possible signal should be used and the least amount of coupling. As the IF is peaked and the signal it passes increases lower the input signal. The combined IF circuit as a whole should be taken into consideration. That is where the IF is functioning so it is best to align it in circuit. Plus it is a lot less hassle to leave it in the circuit if you can. I usually have my generator connected to a frequency counter but as I reduce the signal the counter can no longer read the signal. I just assume that the generator has not shifted in frequency as I attenuated the signal. I also keep the generator on for at least a 1/2 hour before alignment. This is just my "two cents" and should not be taken as an exhaustive rendition of fact.
:MRO
As far as slipping sleeving over the wires goes... thanks and yes I have done that here and there but this radio is one that I'm completely refurbishing and re-painting too... Take a peek:
http://www.pbpix.com/consoltone1.jpg
before and after:
http://www.pbpix.com/consoltone2.jpg
...and then I'll campaign it out on Ebay... so I like to deliver a nice looking reasonably thorough job. Besides almost every wire in this thing needs replacing ... so pulling the IF cans and doing it right was reallly very little extra effort.
They aren't so scary... just pop 'em open and fix them.
There might be something to this?? In TV wires which carry high voltage collect dust.
Can't remember seeing this in radios? Most radios have been off for decades so wire hasn't seen voltage during this time.
:By the way I forgot to mention... whenever I work on these Zenith's with old rubber coated wires... I find that the majority of the wires are all brittle and cracked and any slight movement causes the insulation to crumble off... however there are some wires that are just as soft flexible and suptle as when they were new!.
:Why is this.
:I haven't analyzed this yet... but it seems on the surface, that certain wires like B+ will go bad but cathode circuit, antenna signal wires etc all remain soft.
:Why do you think that is? Wires that carry higher voltages also seem ( on cloth wire) to collect a white fuzzy powerdy stuff too.
MRO
Remember that I aligned the 1st IF can on the bench (passively) by loose coupling my signal generator using a couple of turns of wire...to the tuned transformers and connected my scope to each of the primary and secndarys ....tweaking for max signal as seen on the scope.
After this I re-installed it and tested how it performed audio-wise....without any further tweaking.
then ...I stated here above...that it seems to be perfectly aligned. I assessed this by tuning for a clear stong signal at one particuar freq on the band... then I placed my freq counter probe near the local oscillator and found it to be at exactly 455khz above the station freq. Everything sounded clear sharp and crip... so I concluded that the "passive" adjustment had optimized the IF's performance.
Well... I WAS WRONG..... lol.
Oh eveything did sound clear and sharp. (but that really wasn't enough).... until last night while I was getting ready for final inspection before re-installing in the cabinet... I was tuning across the entire band... and came to a nice (old-time big band)low-power local station at 1160khz... but it was almost obliterated and swamped out by a stronger nearby station on 1130khz.
At first I thought it was just too weak... but after some thought I realized that there must be a problem because the 1130khz station also came in clearly at 1130khz ...but why should it also be so strong 'again' up on 1160khz??
Plus... this Zenith 6D614 is a SIX tube radio providing an extra front-end RF amp/tuner compared to the 5 tubers... so this Zenith should have no problem isolating and bringing in that weaker 1160khz station.
So I cranked up the ole signal generator at 455khz again and fed it into the grid of the converter via a .1uf ... as specified.
I put my digital volt meter on the AVC line and watched for max neg avc voltage as my ears listened for a strong (max) audio peak as well.
Sure enough that 1st IF can was considerably off its "optimum' peak!!!
So as soon as I finised making it right... I tested the radio again for that weaker 1160khz station ...and this time ..there it was!!
It was nice and clear this time and separate from it's neighbors... no swamping out from the 1130khz station.
GREAT! ( thank you Major Armstrong..)
Well so what does this tell me exactly?
I'm not sure why peaking the IF tank circuits "passively" by loose coupling shouldn't also have worked well enough... but it does not... that's for sure.
:Well ... live and learn I guess...
:Remember that I aligned the 1st IF can on the bench (passively) by loose coupling my signal generator using a couple of turns of wire...to the tuned transformers and connected my scope to each of the primary and secndarys ....tweaking for max signal as seen on the scope.
:After this I re-installed it and tested how it performed audio-wise....without any further tweaking.
:then ...I stated here above...that it seems to be perfectly aligned. I assessed this by tuning for a clear stong signal at one particuar freq on the band... then I placed my freq counter probe near the local oscillator and found it to be at exactly 455khz above the station freq. Everything sounded clear sharp and crip... so I concluded that the "passive" adjustment had optimized the IF's performance.
:Well... I WAS WRONG..... lol.
:Oh eveything did sound clear and sharp. (but that really wasn't enough).... until last night while I was getting ready for final inspection before re-installing in the cabinet... I was tuning across the entire band... and came to a nice (old-time big band)low-power local station at 1160khz... but it was almost obliterated and swamped out by a stronger nearby station on 1130khz.
:At first I thought it was just too weak... but after some thought I realized that there must be a problem because the 1130khz station also came in clearly at 1130khz ...but why should it also be so strong 'again' up on 1160khz??
:Plus... this Zenith 6D614 is a SIX tube radio providing an extra front-end RF amp/tuner compared to the 5 tubers... so this Zenith should have no problem isolating and bringing in that weaker 1160khz station.
:So I cranked up the ole signal generator at 455khz again and fed it into the grid of the converter via a .1uf ... as specified.
:I put my digital volt meter on the AVC line and watched for max neg avc voltage as my ears listened for a strong (max) audio peak as well.
:Sure enough that 1st IF can was considerably off its "optimum' peak!!!
:So as soon as I finised making it right... I tested the radio again for that weaker 1160khz station ...and this time ..there it was!!
:It was nice and clear this time and separate from it's neighbors... no swamping out from the 1130khz station.
:GREAT! ( thank you Major Armstrong..)
:Well so what does this tell me exactly?
:I'm not sure why peaking the IF tank circuits "passively" by loose coupling shouldn't also have worked well enough... but it does not... that's for sure.
:Marv:
:... I'm listening.. if you have a long list of why passive tuning doesn't work... please elaborate... I'm anxious to know...
:I am an avid participant in this forum especially for what I can learn...
:so I'm all ears...
When I fed 455kc to each side by loose coupling.. I saw on my scope, connected to each L/C circuit, "when tuned" a stronger large signal (it appeared larger than the input signal as I remember)... so it almost appeared to be oscillating at the applied frequency.
Well whatever..
.... in any case, it's a moot issue as far as tweaking goes.. it certainly would never be practical to tune them "passively" anyway... lol
Just the "Tom Edison-effect" in me doing a bench experiment.
Another aspect to look at is that the tank circuit isn't really creating an oscillation. The oscillation is created elsewhere--in the local oscillator and in the radio transmitter. It is merely vibrating electrically to a frequency that's being sent to it. If your frequency of pushing a swing didn't match the frequency that the swing swung at, sometimes you'd miss the swing, sometimes you'd push it well, and sometimes it'd slam into you. When the length of the swing is tuned to match the rate you wish to push at, then the swing is in resonance with you. The resonance in the electric tank circuit is like that of a swing or pan of water or any other resonance. Currents will oscillate back and forth at a certain frequency until all energy has been spent (probably in undetectable heat). Only if another source of oscillations (the oscillator and transmitter) feeds the circuit, will it continue to oscillate at a constant amplitude.
This also explains why certain IF transformers are marked for certain frequencies. In reality, they can be tuned to just about any frequency the trimmers will allow. However, they have been designed so that when the condensers and coils are in resonance, they meet halfway, or at whatever point is optimum for both the coils and the condensers at the required frequency. You may find that if you put 265KC IF transformers into a radio that requires 455KC IFs, and you are able to tune them to 455KC, that they will not perform as well as IFs designed for 455KC. This may also explain why some radios perform better than others. You may not know it if a manufacturer used the wrong kind of IF transformer simply because there was an abundance of the transformer. I don't know if this practice ever actually took place, but it is possible.
:Each side isn't an oscillator, but rather a resonant tank circuit. It prefers a certain frequency just like a certain sized tub is going to slosh water back and forth at a certain rate, etc. Coils pass lower frequencies progressively better than higher ones. The opposite is true for condensers. The two meet half-way (or somewhere else) at a frequency that they both pass well, and this is the resonant frequency. The electricity sloshes back and forth in the condenser-coil loop at a frequency that both pass equally. Well, I guess you could call it an oscillator, but a passive one, not an active one. It's more of a circuit where oscillations (any resonance is an oscillation) take place--back and forth in the coil-condenser loop. It just so happens that the coil also radiates magnetic pulses, which can be picked up by another coil. The second coil, along with its condenser, are tuned for optimum response so that the currents can slosh back and forth in the loop as efficiently as possible. The grid of the next tube "sees" these oscillations. The reason why a tank circuit requires a condenser and a coil, and not a condenser and condenser or coil and coil, is because they must peak at a certain frequency. If it was coil and coil or condenser and condenser, the two items would pass an infinite number of frequencies, progressively getting better as they went down or up, depending on the items selected (condensers or coils). Sure, as frequencies got higher or lower, they'd pass more easily, but there'd be no selected preferred frequency. If you have a bunch of different frequency sloshes happening in a pan of water (if such a thing could happen on its own), they'd just randomly bump into eachother, and couldn't resonate in a uniform manner.
:Another aspect to look at is that the tank circuit isn't really creating an oscillation. The oscillation is created elsewhere--in the local oscillator and in the radio transmitter. It is merely vibrating electrically to a frequency that's being sent to it. If your frequency of pushing a swing didn't match the frequency that the swing swung at, sometimes you'd miss the swing, sometimes you'd push it well, and sometimes it'd slam into you. When the length of the swing is tuned to match the rate you wish to push at, then the swing is in resonance with you. The resonance in the electric tank circuit is like that of a swing or pan of water or any other resonance. Currents will oscillate back and forth at a certain frequency until all energy has been spent (probably in undetectable heat). Only if another source of oscillations (the oscillator and transmitter) feeds the circuit, will it continue to oscillate at a constant amplitude.
:Thomas
I thought your description was very good!!
Peter, I am doing the exact same thing you are with my 7s582. I want to get precise IF tuning via a scope. Look at last months questions under alignment. You answered one of my questions. I see that a sweep gen. and a scope are only good with multiple IF's. One a single IF the Q of the IF is preset. Does your set have multiple if's? Did you scope align after the set was assembled? I am still trying to figure out how to get a perfect reading (freq counter)on my signal generator.
:I need to change the wires up in my cans but am afraid of disrupting things. The wire coating are still on up in the cans so I might just leave them. Keep me updated
I like using a scope on the things as well. Our ears work on a log scale, which could leave you on either side of a peak without pecieving much of a diffence.
The scope gets it EXACT. The less loading you do with generators or scopes, the better the adjustment will stay the same when they are removed.
I put the generator on the grid circuit, not the transformer. I just clip the scope to the isulation of the plate and crank up the gain. This way the cicuit is working more or less in it's "native" state.
Depending on the how fancy the scope probe is, the capacitve loading to the tuned circuit can be significant. Excessive change in the grid cicuit can also affect the plate capacitance seen by the transformer primary!
:Guess I'm talikng to myself here at 3am.
: what do I expect....lol
:Ok... it's a bit later now.. I put that 1st IF back in now... and fired it up.... Well what perfection!
:Remember... I tweaked it with a small wire loop on the sig gen positioned near each coil as I watched the scope.
:So... ostensibly they'd be tuned perfectly... AND it seems in fact it is.
:I had left the radio tuned to local station at 930kc.
:And after replacing the IF and turning it back on, ...that station came in just about perfectly. After a minute warm up I just slightly rocked the tuner a bit to make sure the signal was maxed... and it just needed the slightest touch and I could hear the audio getting a bit better and then max itself. So I felt I was right on the station as far as my ears could tell.
:( now 930kc + 455kc = 1385kc right?)
:So I put my frequency generator probe close to the local oscillator coil just to see... and..There it was right smack dab on 1385kc!!! ( so it seems that after perfectly tweaking the IF outside the radio... the associated circuit elemnents when back in the radio had no additional loading effect on the IF transformer at all!)
:Nice.
