Foremost is the trapezoidal picture which indicates a problem with the deflection yoke (the coils in the form that surround the neck of the picture tube). It may possibly (slight chance) be that there is a shorted cap that might contribute to this, but I do not have schematic of your set, so it is likely only a very slight chance.
The other issue is in the RF stages, likely just that the tubes are in need of replacement.
Unless you are servicing portions of the tuner, a signal generator is not an absolute necessity, but it does help in some instances. For the most part, a television of the era you have, you can assume for the moment that it was still reasonably close to being in tune before it experienced the current problems.
Your scope is still adequate for servicing the set, as you are dealing with sweep signals of 60 hertz and 15750 hertz, and most likely, you will just need it for checking the level of the "blanking pulse", and the waveforms of the signals to the Cathode, and grids.
The modern theories still apply, but instead of a chunk of silicon, your amplifiers have a vacuum and heaters.
: I have a motorola tv 1959 I guess...model y21t57ch
: no sound, just a hiss, screen lights up but no
: picture, and the left side of the screen is
: shrunk in a little. I have no idea where to start
: or how. since I have a degree in MODERN electronics,
: I have never worked on the old stuff. dont have a
: signal generator and my oscope is only rated at 20 meg
: have not worked on the new radios or tvs either...so
: if anybody could lend me a helping hand or
: direction to start, that would be greatly
: appreciated. Ive got a lot of cool radios I,ve
: collected also, but would like to fix them
: (some do work), not blow them up doing something
: wrong.
: So as to the tv do I replace all the really old looking
: caps that I can find then start locating the various
: troubles(not that I would really know
: what they are anyway!) Thats part of the problem
: I dont know tv terminology
On the 3 sets I have repaired I have learned to replace all paper caps first. It seems that they leak and cause all sort of problems. Also the filter caps go bad and need to be replaced without question. I have tried to fix just the problem in the set without replacing all the paper or round plactic black caps but always end up replacing them all.
But once that is done 2 set fired up and worked with no problems after that the other needed a contact cleaned in a tube socket.
Also a tube tester is a good tool to have. A shorted or week tube can set you mad. If you don't have one then swaping tubes can also work.
Hope this helps.
Tom Guest
: wrong.
