The output signal is either there or not there.
The signal output level must however be sufficient for the input threshold level of your frequency counter.
You signal generator should be able to read the signal thogh unless your generator's output is extremely low do to some failure.
The important thig is that you must NOT be modulating the signal generator with augio at the time of your reading as the that can confuse your signal generator.
There should be a 400hz or 1000hz audio modulation on/of switch somewhere on the generator.
You should have it OFF when you read the signal gen's output with the Freq counter. Them you can turn it to the freq you like such as 455khz.
Then later when you couple the signal generator's output to the radio ....THEN you can turn the audio modulator on.
I just tested my cheapo handheld multimeter...
Supposed to have a freq reading range of 10hz to 10mhz
Doesn't say threshold levels.
Anyway it seems it can read the low frequencies like 60hz by just being close to the AC line. I can also read the audio out from my Heathkit model 1G-102 sig gen. because that puts out mucho volts (AC)... like 50v pp AC as seen on my o'scope. And the meter reads it all the way down to about a few volts.
But it doesn't read a thing on the RF side that seems to only put out about 500mv pp.
I don't have the sig gen specs to see if the RF level is below spec... but I do know using it everday that it's always plenty for my radios.
:What are the specs of your digital freq meter? Do not know the specs.
Are you saying that you cant get a reading on the RF side of your signal generator either? I will measure the output of my generator tonight. The strange thing is that my counter will go up to the top of the first band (431kc) yet when I switch to the second band, 431kc+, the counter goes to 000. You mention voltage on the higher freq's but I would think going from 431kc to 455kc should not be that big of deal.
