When I got this one it was working, albeit not well, so I began my usual process of cleaning, testing, recapping etc.
After I completed all of my work I got to my bench testing. Brought it up on the variac, all tubes lighting, no smoke, smells etc.
The issue is that I get nothing out of this unit just a very soft hum. Adjusting volume does nothing. So I fire up my signal gen and get it near the set (usually I can pick up my signal gen on radios 10 ft away) and still nothing. So I connect directly up to the tuning gang and I get signal, soft signal, but signal at least. Same if I couple to the antenna.
I adjust the signal gen to the frequency of my local AM station (their towers are a mile from my house and they usually boom in through all my sets) track the dial till I get signal from the gen at that frequency, remove the gen and listen carefully to see if I hear the station. Nuttin, nada, zilch, zero.
I can't seem to get any reception at all yet I can get signal from the generator coupled directly which tells me my stages are working I assume.
Where do I start looking????
CMcKenna,
It has been said many times before but, do you get a loud hum when touching the center terminal of the volume control with with a screwdriver? You should get a loud hum if the audio preamp, inverter and output tubes and etc. are ok.
CMcKenna,
I have done the same thing a few times myself.
