If you can get a copy of an old logo or dial scale. Just scan it or save the digital image found on-line and import it into your graphic program ( I use photoshop) then simply print out either with a laser-printer or inkjet-printer onto the 'clear' water-transfer paper. Then spray it with Krylon if you want a shiny surface that faces right-reading normal .
Or just spray to protect it a bit if you are transferring ( wrong-reading or reverse) onto the back of a dial glass ot plastic dial lense.
here's a source for the material and plenty of examples and instructions:
http://www.decalpaper.com/
also here:
http://www.hyaz.com/inkjet%20waterslide%20decal%20paper.html
:I think this is a GREAT way to make replacement dial scales. To transfer onto glass or plexi-glass or the more flexible thinner bendable 20 mil poly-acrylic or mylar plastic dials or whatever clear plastic.
:Also for making front panel 'volume' or 'tone' control indicators and cretainly for replacing logos.
:If you can get a copy of an old logo or dial scale. Just scan it or save the digital image found on-line and import it into your graphic program ( I use photoshop) then simply print out either with a laser-printer or inkjet-printer onto the 'clear' water-transfer paper. Then spray it with Krylon if you want a shiny surface that faces right-reading normal .
:Or just spray to protect it a bit if you are transferring ( wrong-reading or reverse) onto the back of a dial glass ot plastic dial lense.
:here's a source for the material and plenty of examples and instructions:
:http://www.decalpaper.com/
:also here:
:http://www.hyaz.com/inkjet%20waterslide%20decal%20paper.html
I was commenting only on water-Decals... and the materials for that.
Now...I've probably been told to ''get flocked'' many times I'm sure... but I have not done anything with flocking publicly.. at least not to my knowledge... so I'm confused ...lol
You must have been replying to something else... no?
:Marv:
:Huh? Re-flocking??
:I was commenting only on water-Decals... and the materials for that.
:Now...I've probably been told to ''get flocked'' many times I'm sure... but I have not done anything with flocking publicly.. at least not to my knowledge... so I'm confused ...lol
:You must have been replying to something else... no?
