I went to a fabric shop as you suggested on my 1948 Zenith. The closest fabric I found was prettier than the original, having gold and yellow in it. In the radio it looks great.
This makes me wonder. Could the dyes in my original have faded such that the original had become drab?
A while ago I did an Airline Miracle. When I went to replace the felts around the push buttons I noticed that they had a slight red tint to them, indicating that they had been red, eventhough they were then black. The grill cloths on the top, also showed red in the places where the bakelite bars crossed them.
Is there any record of original color schemes? Has anyone gotten into restoration of original dye color schemes?
All the Best,
Bill G.
:Hi All,
:I went to a fabric shop as you suggested on my 1948 Zenith. The closest fabric I found was prettier than the original, having gold and yellow in it. In the radio it looks great.
:This makes me wonder. Could the dyes in my original have faded such that the original had become drab?
:A while ago I did an Airline Miracle. When I went to replace the felts around the push buttons I noticed that they had a slight red tint to them, indicating that they had been red, eventhough they were then black. The grill cloths on the top, also showed red in the places where the bakelite bars crossed them.
:Is there any record of original color schemes? Has anyone gotten into restoration of original dye color schemes?
:All the Best,
:Bill G.
Also, on the same note, an Airline portable I own used to be kind of turquois--the cloth, that is. The plastic knobs still are. The cloth has turned a dark green, though, due to yellowing of the lacquer.
Regarding fading, sunlight and fluorescent light do terrible things. Unless your dyes are finely powdered minerals that have already been exposed to the sun, they will likely fade.
How do you find the original grill cloth colors?
All the Best,
Bill
:Well, the best way, if all you have is your cloth, is to remove the cloth, or the cloth-baffle assembly, if the cloth is mounted to a baffle (board). Then inspect the cloth where it was covered by the cabinet. It will be darker, and closer to original colors, here.
:Thomas
:You can't. You'll only dye it one color when there are multiples. If I can't find someone to make a replica of my speaker cloth, I will just have to do it myself. It'll take a long time, but I know I can do it. It shouldn't be any more complicated than winding a motor armature. A loom is how it is done, and you'd have to do it the old fashioned way unless you knew someone with a modern computerized loom.
:T.
Regarding looms, you have base threads of a base color. Then you have cross threads (not sure if the terminology is correct) of the other colors you want to work in. You lift the base threads where you don't want the cross threads to show, and you drop them when you want the cross threads to show. For each cross thread you must set the base threads properly to continue the desired pattern. TONS of work. Someday, when I have surplus time (don't see that in the near future), I'll undertake this huge project if I don't find an alternative. Given the size of the necessary cloth, it shouldn't take too long. Perhaps it will take about 20 hours, so about a few days.
Thank you for the low down on grill cloths. I have found the fabric store to be a great benefit. The guy that owns it is a collector of vintage radios, too!
As far the loom, I have kids to raise, maybe someday I will have the time, but not now.
All the Best,
Bill Grimm
Hi Thomas,
May I suggest a girl friend who likes weaving, quilting and dress making?
All the Best,
Bill
