Zenith Part # 20-135 R F coil
10/17/2006 8:37:38 PMLarry Smoot
I need a coil for a Zenith 12-S-266. On the schematic it's item # 9, Zenith part # 20-135. The same coil is also used in several similar models. Anybody got a spare?
Larry
10/18/2006 10:02:46 AMNorm Leal
Hi Larry
Check with PTOP for the coil. If you don't find what you want give them a call.
http://www.oldradioparts.com/2a6fla.txt
:I need a coil for a Zenith 12-S-266. On the schematic it's item # 9, Zenith part # 20-135. The same coil is also used in several similar models. Anybody got a spare?
:Thanks,
:Larry
10/25/2006 8:15:20 PMLarry Smoot
Thanks Norm.
He has many coils, but not the one I need. I'm still looking.
Larry
:Hi Larry
: Check with PTOP for the coil. If you don't find what you want give them a call.
:http://www.oldradioparts.com/2a6fla.txt
::I need a coil for a Zenith 12-S-266. On the schematic it's item # 9, Zenith part # 20-135. The same coil is also used in several similar models. Anybody got a spare?
::Thanks,
::Larry
