: Marv, unless there is some special lube used by those who restore phonos, I stay with the 3in1. I tried grease on a turn table one time and it was enough drag to slow down the turn table, had to take it apart and remove the grease. PL
Lou
: Marv, whatever grease you use must be very thin, I don't know if thats the correct discription but any drag, even from the grease is enough to slow down the turntable. I'm wondering if some type of graphite might work better. PL
:I think graphite would be a good choice. For one it DOESN'T attract dirt. Might be a little messy, all depends on what you are lubing. Motor shafts would probly be better off with the 3n'1.
