chassis is hot?
9/24/2006 6:26:44 PMallen
I have an heathkit audio generator mdl ig-72 powered thru an isolation transformer but I'm measuring 160vac from chassis to earth ground the generator has its own power transformer.
9/24/2006 6:59:07 PMDoug Criner
Have you been shocked? Probably just stray capacitance if you're measuring with a DMM or VTVM. If you have an analog (mechanical) voltmeter, which has lower input impdedance, try that.
Otherwise, temporarily connect a 50K +/- resistor from chassis to earth ground, and then measure the voltage with your DMM.
:I have an heathkit audio generator mdl ig-72 powered thru an isolation transformer but I'm measuring 160vac from chassis to earth ground the generator has its own power transformer.
