I have a Scott speaker that has a finger sized hole in it. There is not enough speaker fabric left to fill in the hole during the repair process. I have heard that contruction paper is used fill in such holes. Any other ideas? ... thanks.
If it is in the fabric of the grille cloth, a seamless repair is not the easiest to accomplish, and may not work. Construction paper can give you a match for color, but will only make the damage a little less visible. If you can get to frayed ends of the fabric, you might try to "reweave" the area with some of the longer frayed end threads, but here again, it won't be perfect.
: Hi all,
: I have a Scott speaker that has a finger sized hole in it. There is not enough speaker fabric left to fill in the hole during the repair process. I have heard that contruction paper is used fill in such holes. Any other ideas? ... thanks.
