Superior TV-11 settings
9/21/2006 5:16:42 PMR Sharp
What settings should be used to test the following tubes on the Superior TV-11 ?
35/51
47
The settings for these tubes are not on the roll chart nor on an additional supplement that I have.
Thanks in advance.
9/21/2006 9:52:09 PMBOB BONCHAK
:What settings should be used to test the following tubes on the Superior TV-11 ?
:35/51
:47
:The settings for these tubes are not on the roll chart nor on an additional supplement that I have.
:Thanks in advance.
Try: V:2.5, F:1, G:TC, P:2,3, CIR:A, SENS:35, FIL. CONT:5 for the 35/51.
For the 47 try V:2.5, F:1, G:3, P:2.4, CIR:B, SENS:65, FIL: CONT:5
Above were taken from the TV-12 1962 Supplement, but should work in your circumstance. I do have TV-11 settings data but don't have the time now to search for them.
BOB
9/22/2006 3:02:40 PMRoy Sharp
::What settings should be used to test the following tubes on the Superior TV-11 ?
::35/51
::47
::The settings for these tubes are not on the roll chart nor on an additional supplement that I have.
::Thanks in advance.
:Try: V:2.5, F:1, G:TC, P:2,3, CIR:A, SENS:35, FIL. CONT:5 for the 35/51.
:For the 47 try V:2.5, F:1, G:3, P:2.4, CIR:B, SENS:65, FIL: CONT:5
:Above were taken from the TV-12 1962 Supplement, but should work in your circumstance. I do have TV-11 settings data but don't have the time now to search for them.
:BOB
9/22/2006 3:09:48 PMRoy Sharp
Hi Bob..
Thanks for your info, however the titles on my roll chart on the TV-11 are:
FIL V
F
N
P
Load
Fil cont
How do the TV-12 settings that you provided convert to these settings.
Roy
9/22/2006 12:57:19 AMMarv Nuce
I have a restored TV-11 with the same roll chart. Actually had so many problems with the mechanism, removed the chart from the tester, and it stands alone, but works well.
:35/51
:47
:Thanks in advance.
9/22/2006 3:12:31 PMRoy Sharp
Hi Marv...
Does your TV-11 roll chart have the settings for tubes 35/51 and the 47?
Roy
9/22/2006 3:41:57 PMMarv Nuce
Roy,
No, same problem as your's.
:Hi Marv...
:Does your TV-11 roll chart have the settings for tubes 35/51 and the 47?
:Thanks,
:Roy
