I've been turning over every rock I can. I had this radio pumping out beautifully with the eye closing almost all the way. It sounded great!
As the last part of this project I rebuilt the casing for and re-wired the 5 wire harness to the antenna, now I get nothing. Well, not really nothing, I get am 570 out of DC here, but that's all I get and no matter where I tune, no matter the position of the tuning condenser, I still get am 570 with no fluctuation on the eye. That may just be an RF thing, but there are more powerful stations in the area.
There's got to be a short in the antenna somewhere. The only thing I changed was the wiring (because the original was literally falling apart). A lesson in leaving well enough alone.
Thanks as always, Dan
:Does anyone know where I may be able to find a schematic of the Wave Magnet Roto Antenna for the Zenith 8S463? Unlike most Wave Magnets, it has a 5 pin connector. The antennas I've been seeing for sale are all 4 pin. Heck, this one was in such bad shape I'd even consider finding another if I could.
:I've been turning over every rock I can. I had this radio pumping out beautifully with the eye closing almost all the way. It sounded great!
:As the last part of this project I rebuilt the casing for and re-wired the 5 wire harness to the antenna, now I get nothing. Well, not really nothing, I get am 570 out of DC here, but that's all I get and no matter where I tune, no matter the position of the tuning condenser, I still get am 570 with no fluctuation on the eye. That may just be an RF thing, but there are more powerful stations in the area.
:There's got to be a short in the antenna somewhere. The only thing I changed was the wiring (because the original was literally falling apart). A lesson in leaving well enough alone.
:Thanks as always, Dan
:Dan,
:One thing I noticed when re-wiring a built in antenna was the wire. The bulk of the radio was wired with #22 solid, except for the tuning, osc and antenna (all RF) circuits, wired with #22 stranded. I suspect that in all cases the solid wire would alter the inductance of an osc coil as well as the antenna circuit, and probably de-tune the whole set. The fact that you only get 1 station though, would lead me to believe that the antenna coil and oscillator circuits are mis-wired, and not actually tuning.
:marv
::Does anyone know where I may be able to find a schematic of the Wave Magnet Roto Antenna for the Zenith 8S463? Unlike most Wave Magnets, it has a 5 pin connector. The antennas I've been seeing for sale are all 4 pin. Heck, this one was in such bad shape I'd even consider finding another if I could.
::I've been turning over every rock I can. I had this radio pumping out beautifully with the eye closing almost all the way. It sounded great!
::As the last part of this project I rebuilt the casing for and re-wired the 5 wire harness to the antenna, now I get nothing. Well, not really nothing, I get am 570 out of DC here, but that's all I get and no matter where I tune, no matter the position of the tuning condenser, I still get am 570 with no fluctuation on the eye. That may just be an RF thing, but there are more powerful stations in the area.
::There's got to be a short in the antenna somewhere. The only thing I changed was the wiring (because the original was literally falling apart). A lesson in leaving well enough alone.
::Thanks as always, Dan
Dan,
You may take a look at the 8S462 in the resources on this site. It has a 5 wire wavemagnet. It may help with tracing out the wiring of your wavemagnet. Note that the external antenna ground is returned to B minus thru a capacitor and not to chassis as yours.
:Marv,
:Thank you for the tip. I'll give that a look this evening. You wouldn't happen to know the pin outs on that antenna would you? That's where I'm tripping up. Thanks again, Dan
::Dan,
::One thing I noticed when re-wiring a built in antenna was the wire. The bulk of the radio was wired with #22 solid, except for the tuning, osc and antenna (all RF) circuits, wired with #22 stranded. I suspect that in all cases the solid wire would alter the inductance of an osc coil as well as the antenna circuit, and probably de-tune the whole set. The fact that you only get 1 station though, would lead me to believe that the antenna coil and oscillator circuits are mis-wired, and not actually tuning.
::marv
:::Does anyone know where I may be able to find a schematic of the Wave Magnet Roto Antenna for the Zenith 8S463? Unlike most Wave Magnets, it has a 5 pin connector. The antennas I've been seeing for sale are all 4 pin. Heck, this one was in such bad shape I'd even consider finding another if I could.
:::I've been turning over every rock I can. I had this radio pumping out beautifully with the eye closing almost all the way. It sounded great!
:::As the last part of this project I rebuilt the casing for and re-wired the 5 wire harness to the antenna, now I get nothing. Well, not really nothing, I get am 570 out of DC here, but that's all I get and no matter where I tune, no matter the position of the tuning condenser, I still get am 570 with no fluctuation on the eye. That may just be an RF thing, but there are more powerful stations in the area.
:::There's got to be a short in the antenna somewhere. The only thing I changed was the wiring (because the original was literally falling apart). A lesson in leaving well enough alone.
:::Thanks as always, Dan
The ideal set-up is found on a Zenith portable, where the wires are sewn on each side of a cloth band. They are kept about 1.5 inches apart at all times.
I think it's that 5th wire that's really creating the problem. There was a 5th wire coming out of the wave magnet, but was NOT attached to the chassis when I started the restoration. There was, however, an open pin on the connector...silly me, I assumed that that was where it was supposed to go (again, that wave magnet isn't drawn out in the kind of detail I need). If that 5th wire doesn't get wired to chassis, where should it go?
Thanks again.
:Also, when the antenna wiring is bad, it is always a good idea to replace it. Otherwise you can't rotate the antenna for best reception. In the future, though, replace only one wire at a time. Also, keep the wires separated somewhat, perhaps by using thick insulated wires (although I don't think that the originals had thick insulation). If the wires are placed too close together, the capacitance between them will keep the set from tuning high.
:The ideal set-up is found on a Zenith portable, where the wires are sewn on each side of a cloth band. They are kept about 1.5 inches apart at all times.
:T.
