Regards
Unless you have a portable that you're taking to the beach, though, you're better off using a battery converter. It'll cost you less in the long run.
Can those converters be purchased or is it kits that have to be made up?
Thanks.
Job
You can purchase "battery eliminators" from places like AES, or if you need/want portability, make your own B+ arrangements using cheaper 9V batteries in series. "A" battery arrangements can be made from C or D cells in parallel/series as necessary.
Job
:::Yep. Radios that need 67.5 volts, use a 67.5 volt battery. Radios that need 90 volts, use two 45s in series. Batteries Plus has these kinds of batteries, too, including some 300 volt ones.
:::Unless you have a portable that you're taking to the beach, though, you're better off using a battery converter. It'll cost you less in the long run.
:::Thomas
::Can those converters be purchased or is it kits that have to be made up?
::Thanks.
::Job
:You can purchase "battery eliminators" from places like AES, or if you need/want portability, make your own B+ arrangements using cheaper 9V batteries in series. "A" battery arrangements can be made from C or D cells in parallel/series as necessary.
