Use incandescent lighting for your bench and kill those over head florescent lights....maybe get a couple of those articulatined arm or gooseneck lamps.
OR:
Rewire your bench area so that your bench is powered from a different circuit than those lights.
Another nasty source of interference is dimmer switches. The dimmer the lighting, the louder the buzz they generate.
I was thinking though..........perhaps an isolated power supply for your project radio would eliminate the problem as well......not sure about that though. Hopefully some of the other members will jump in here.
:My shop has overhear florescent lights. this lights create lots of noice on the AM band. what can I do to cut down this noise. Thanks, Bud
:Place a .1 MFD condenser across the AC wiring on each fluorescent. See if this works. If not, purchase some 100 mH chokes from Radio Shack (ferrite rod with two layers of wire). Place one on each side of the AC line for each fluorescent. All components should be inside of the fluorescent housing. Try set-up with a .1 MFD condenser before and after the chokes, across the AC wiring. Experiment with just one before or just one after. See if one way or the other or both works best for you. You can also try two .1 MFD units in series on each side of the chokes, with their center junction tied to the metal housing of the fluorescent. Again, try this on the fluorescent side of the chokes, on the AC side of the chokes, and then on both sides, to see which way cuts out noise the most.
:Thomas
:True, true, but I have had a lot of luck with filters on the fluorescent line. As I said before, the filters must be experimentally applied. One filter doesn't necessarily work well in all cases. Start with one condenser. Elaborate from there.
:Thomas
I can usually make fluorescents very silent. The solid state ones are the worst. Also, it's a good idea to make use of the external antenna wire on all radios, even if equipped with loops. I can get fairly static-free reception in my parents' basement, though, with tons of fluorescents and steel furnace pipes, and I haven't even done anything to their fluorescents. The one solid state unit towards one end of my dad's bench makes a bit of noise, but the others are pretty quiet. I'm sure that with some filtering, I could make things silent.
:Ground the fluorescents. Try Norm's idea of a hardware mesh over the tubes (grounded to the metal chassis). Then try various filter techniques.
:I can usually make fluorescents very silent. The solid state ones are the worst. Also, it's a good idea to make use of the external antenna wire on all radios, even if equipped with loops. I can get fairly static-free reception in my parents' basement, though, with tons of fluorescents and steel furnace pipes, and I haven't even done anything to their fluorescents. The one solid state unit towards one end of my dad's bench makes a bit of noise, but the others are pretty quiet. I'm sure that with some filtering, I could make things silent.
:Thomas
:Well, because it's AC. A capacitor meter measures capacitance by passing an AC frequency through it. The more the frequency passes through, the lower the value of the condenser.
:Thomas
:Possible. 60 cycles probably wouldn't normally affect a 60 something pf condenser. What happens when your leads are moved around? Do they have thick enough insulation? The 60 cycles isn't affecting the condenser, though. It's simply radiating directly into the leads. I don't have much experience with capacitance meters (though I really want to buy a Solar one some day...old, with eye tube and meter, in a wooden box). However, I assume that a capacitance meter simply has a signal source and then a device that detects the signal passage (say, an amplifier, which drives the meter through a detector (diode) of sorts that converts the signal to DC for the meter). If this is the way the design works, then all that is needed is for stray alternating current to get into the detection lead. What happens when you grab each of the leads separately? Does one make the meter swing up?
:T.
