:Hey all, I got this radio about 3 years ago , I do not have the cone centric tool to adjust the pre-sets , so I just tune it normally, although I see the philco repair bench has a link to them , but my question is the large knob or the fine tuning , It does not make any difference if you depress it and turn it either way on my set, It does not apear to engage anything when depressed so is mine missing something? the article on philco repair bench does not elaborate on this function, anyone able to shed light on how this is suppose to work?
:Thanks
My large knob just engages the outer ring of the dial for manual tuning. You can also pull out the small knob and turn the tuning.
The cone-centric tool allows loosening and adjusting the cones with the dial mechanism all together - by inserting the tool through the small knob. The reproduction tool that is being sold is just a cheap screwdriver with the tip ground into a shape that will engage the cones. You can probably fashion your own. The repro tool isn't strong enough to loosen stuck cones, so you first need to loosen them with a pair of vise-grips.
But back to your original question - I'm not sure I understand what your issue is with the large knob. Doesn't it engage the large 6" knurled brass ring around around the tuning dial for fine tuning? That's what my large knob does, nothing more, nothing less.
::Hey all, I got this radio about 3 years ago , I do not have the cone centric tool to adjust the pre-sets , so I just tune it normally, although I see the philco repair bench has a link to them , but my question is the large knob or the fine tuning , It does not make any difference if you depress it and turn it either way on my set, It does not apear to engage anything when depressed so is mine missing something? the article on philco repair bench does not elaborate on this function, anyone able to shed light on how this is suppose to work?
::Thanks
Regarding fine tuning, again, I don't have this set, so I don't know what goes on inside of it. My Airline has a push to tune fine tuning knob. Inside there's a rubber washer that sits on the shaft, with a brass washer/flange towards the front to support the washer. The washer is nothing more than a valve washer. These can be found in many sizes and either flat or conical at your hardware store. If that's what your radio uses, and is missing, then that's how you can fix the problem.
:Thanks for your reply Doug, according to philco repair bench the large knob is suppose to be able to push in against the spring and fine tune the radio?? mine all it does when you push it in and turn it is nothing , mine does not engage anything when pushed in, did I read the article wrong? and the large knob is not for veriner tuning?
::Elton, I have a Philco 38-4, which has the cone-centric tuning. I assume my set's tuning mechanism is similar to your 38-7?
::My large knob just engages the outer ring of the dial for manual tuning. You can also pull out the small knob and turn the tuning.
::The cone-centric tool allows loosening and adjusting the cones with the dial mechanism all together - by inserting the tool through the small knob. The reproduction tool that is being sold is just a cheap screwdriver with the tip ground into a shape that will engage the cones. You can probably fashion your own. The repro tool isn't strong enough to loosen stuck cones, so you first need to loosen them with a pair of vise-grips.
::But back to your original question - I'm not sure I understand what your issue is with the large knob. Doesn't it engage the large 6" knurled brass ring around around the tuning dial for fine tuning? That's what my large knob does, nothing more, nothing less.
::::Hey all, I got this radio about 3 years ago , I do not have the cone centric tool to adjust the pre-sets , so I just tune it normally, although I see the philco repair bench has a link to them , but my question is the large knob or the fine tuning , It does not make any difference if you depress it and turn it either way on my set, It does not apear to engage anything when depressed so is mine missing something? the article on philco repair bench does not elaborate on this function, anyone able to shed light on how this is suppose to work?
::::Thanks
There is no spring behind my large knob, at least not now. Yes, I would call it a fine tuning knob or a vernier, take you pick.
My tuning dial is surrounded by a brass ring which is knurled and which rotates along with the tuning. When you push on the large knob and turn it, it gets some traction on the brass ring and turns it. Does your model have the brass ring around the dial?
The inside of my large knob is smooth. It gets traction on the brass ring just through friction.
::::Thanks
:Hmmm, maybe the cone-centric tuning on your model is different than for my 38-4.
:There is no spring behind my large knob, at least not now. Yes, I would call it a fine tuning knob or a vernier, take you pick.
:My tuning dial is surrounded by a brass ring which is knurled and which rotates along with the tuning. When you push on the large knob and turn it, it gets some traction on the brass ring and turns it. Does your model have the brass ring around the dial?
:The inside of my large knob is smooth. It gets traction on the brass ring just through friction.
::Thanks for your reply Doug, according to philco repair bench the large knob is suppose to be able to push in against the spring and fine tune the radio?? mine all it does when you push it in and turn it is nothing , mine does not engage anything when pushed in, did I read the article wrong? and the large knob is not for veriner tuning?
:::Elton, I have a Philco 38-4, which has the cone-centric tuning. I assume my set's tuning mechanism is similar to your 38-7?
:::My large knob just engages the outer ring of the dial for manual tuning. You can also pull out the small knob and turn the tuning.
:::The cone-centric tool allows loosening and adjusting the cones with the dial mechanism all together - by inserting the tool through the small knob. The reproduction tool that is being sold is just a cheap screwdriver with the tip ground into a shape that will engage the cones. You can probably fashion your own. The repro tool isn't strong enough to loosen stuck cones, so you first need to loosen them with a pair of vise-grips.
:::But back to your original question - I'm not sure I understand what your issue is with the large knob. Doesn't it engage the large 6" knurled brass ring around around the tuning dial for fine tuning? That's what my large knob does, nothing more, nothing less.
:::::Hey all, I got this radio about 3 years ago , I do not have the cone centric tool to adjust the pre-sets , so I just tune it normally, although I see the philco repair bench has a link to them , but my question is the large knob or the fine tuning , It does not make any difference if you depress it and turn it either way on my set, It does not apear to engage anything when depressed so is mine missing something? the article on philco repair bench does not elaborate on this function, anyone able to shed light on how this is suppose to work?
:::::Thanks
:Well I guess my radios problem was the chassis was not centered to well, because if I depressed the knob to the knurled brass it would not move it , I re-centered the chassis so the tuner moves more freeley so now the knob does tune it although not very accurate as it can slip and slide , maybe thats why Philco gave up on this design only after 2 years of production, Thanks to all for your help. as rene said you learn something new every day.
:E.
::I have a 38-7 too and up till now, I thought the big knob had no useful function. But after reading Doug's comments, it is indeed for fine tuning by pushing it up against the knurled brass ring that holds the dial glass in place. I learn something new every day!
:::Hmmm, maybe the cone-centric tuning on your model is different than for my 38-4.
:::There is no spring behind my large knob, at least not now. Yes, I would call it a fine tuning knob or a vernier, take you pick.
:::My tuning dial is surrounded by a brass ring which is knurled and which rotates along with the tuning. When you push on the large knob and turn it, it gets some traction on the brass ring and turns it. Does your model have the brass ring around the dial?
:::The inside of my large knob is smooth. It gets traction on the brass ring just through friction.
::::Thanks for your reply Doug, according to philco repair bench the large knob is suppose to be able to push in against the spring and fine tune the radio?? mine all it does when you push it in and turn it is nothing , mine does not engage anything when pushed in, did I read the article wrong? and the large knob is not for veriner tuning?
:::::Elton, I have a Philco 38-4, which has the cone-centric tuning. I assume my set's tuning mechanism is similar to your 38-7?
:::::My large knob just engages the outer ring of the dial for manual tuning. You can also pull out the small knob and turn the tuning.
:::::The cone-centric tool allows loosening and adjusting the cones with the dial mechanism all together - by inserting the tool through the small knob. The reproduction tool that is being sold is just a cheap screwdriver with the tip ground into a shape that will engage the cones. You can probably fashion your own. The repro tool isn't strong enough to loosen stuck cones, so you first need to loosen them with a pair of vise-grips.
:::::But back to your original question - I'm not sure I understand what your issue is with the large knob. Doesn't it engage the large 6" knurled brass ring around around the tuning dial for fine tuning? That's what my large knob does, nothing more, nothing less.
:::::::Hey all, I got this radio about 3 years ago , I do not have the cone centric tool to adjust the pre-sets , so I just tune it normally, although I see the philco repair bench has a link to them , but my question is the large knob or the fine tuning , It does not make any difference if you depress it and turn it either way on my set, It does not apear to engage anything when depressed so is mine missing something? the article on philco repair bench does not elaborate on this function, anyone able to shed light on how this is suppose to work?
:::::::Thanks
:Elton, maybe you can spray some kind of adhesive on the back side of the large knob to improve traction.
::Well I guess my radios problem was the chassis was not centered to well, because if I depressed the knob to the knurled brass it would not move it , I re-centered the chassis so the tuner moves more freeley so now the knob does tune it although not very accurate as it can slip and slide , maybe thats why Philco gave up on this design only after 2 years of production, Thanks to all for your help. as rene said you learn something new every day.
::E.
:::I have a 38-7 too and up till now, I thought the big knob had no useful function. But after reading Doug's comments, it is indeed for fine tuning by pushing it up against the knurled brass ring that holds the dial glass in place. I learn something new every day!
::::Hmmm, maybe the cone-centric tuning on your model is different than for my 38-4.
::::There is no spring behind my large knob, at least not now. Yes, I would call it a fine tuning knob or a vernier, take you pick.
::::My tuning dial is surrounded by a brass ring which is knurled and which rotates along with the tuning. When you push on the large knob and turn it, it gets some traction on the brass ring and turns it. Does your model have the brass ring around the dial?
::::The inside of my large knob is smooth. It gets traction on the brass ring just through friction.
:::::Thanks for your reply Doug, according to philco repair bench the large knob is suppose to be able to push in against the spring and fine tune the radio?? mine all it does when you push it in and turn it is nothing , mine does not engage anything when pushed in, did I read the article wrong? and the large knob is not for veriner tuning?
::::::Elton, I have a Philco 38-4, which has the cone-centric tuning. I assume my set's tuning mechanism is similar to your 38-7?
::::::My large knob just engages the outer ring of the dial for manual tuning. You can also pull out the small knob and turn the tuning.
::::::The cone-centric tool allows loosening and adjusting the cones with the dial mechanism all together - by inserting the tool through the small knob. The reproduction tool that is being sold is just a cheap screwdriver with the tip ground into a shape that will engage the cones. You can probably fashion your own. The repro tool isn't strong enough to loosen stuck cones, so you first need to loosen them with a pair of vise-grips.
::::::But back to your original question - I'm not sure I understand what your issue is with the large knob. Doesn't it engage the large 6" knurled brass ring around around the tuning dial for fine tuning? That's what my large knob does, nothing more, nothing less.
::::::::Hey all, I got this radio about 3 years ago , I do not have the cone centric tool to adjust the pre-sets , so I just tune it normally, although I see the philco repair bench has a link to them , but my question is the large knob or the fine tuning , It does not make any difference if you depress it and turn it either way on my set, It does not apear to engage anything when depressed so is mine missing something? the article on philco repair bench does not elaborate on this function, anyone able to shed light on how this is suppose to work?
::::::::Thanks
