So if any of you have this model... or even documentation that shows it or describes it I sure would be greatful.
I may have actually solved my own problem here with this missing friction wheel thingie.
The print actually does define the mechanism as a "rubber tipped shaft" friction drive.
My problem was that the make-shif grommet I WAS using that I stretched over the 1/4" diameter shaft wasn't shaped right on the outer diameter to meet the big wheel edge properly. Seemed like I really needed something with a larger OD that fits on front and slightly to the side of the big wheel so the two can meet at right angles better.
That seemed to mean that the rubber thingie might need to be tapered or cone shaped to fit properly.
Well... looking around at my old old rusty 1966 garage tool box... I came across a box of various sized hard rubber faucet seat washers...TAPERED too !!!
So I cerfully drilled out the inside diameter to 1/4" and in the tightest of cramped locations I tried ( with all my 6 fingers that I have left...lol)
...tried to force this hard rubber washer up over the back of the shaft 76 flat metal stop-washer on the end and between that washer and the next larger stop-washer about a 1/4" further down the shaft.
Oh my god... it was worse than trying to force a baby back up into that space from which it was just squished out!!
In fact I will say it was harder than "trying to pick up a turd by the clean end" .... !!
... BUT I DID it.... there it is & fits against that big whell exactly as I might have ever imagined it. Now if that somewhat poorly stretchable hard-type rubber doesn't start to split or crack somehow ... I think I may have solved my own problem
But thank you for any imput or feedback you mechanically creative types may have about any better solutions guys.
