Bad electrolytic filter caps can damage the 117Z3 tube. The caps can draw excessive current, heat and blow the cathode connection in the tube.
Can your tube tester test any 117 volt tubes? The 117Z3 is a rectifier with plate on pin #5 and cathode on pin #6. Pin #6 should have around 120 volts DC if the tube is ok.
: I have a Zenith Transoceanic Model 8GOO5 which I bought not working. I tested all the tubes and all tested good however, the 117Z3 rectifier tube was not on any of my tube charts for either my Mercury 1100 or my Precision 10-12 tester. I bought a replacement 117Z3 and tried the radio and it worked. However, after an hour or so, the radio quit working.
: Bad electrolytic filter caps can damage the 117Z3 tube. The caps can draw excessive current, heat and blow the cathode connection in the tube.
: Can your tube tester test any 117 volt tubes? The 117Z3 is a rectifier with plate on pin #5 and cathode on pin #6. Pin #6 should have around 120 volts DC if the tube is ok.
: Norm
: : I have a Zenith Transoceanic Model 8GOO5 which I bought not working. I tested all the tubes and all tested good however, the 117Z3 rectifier tube was not on any of my tube charts for either my Mercury 1100 or my Precision 10-12 tester. I bought a replacement 117Z3 and tried the radio and it worked. However, after an hour or so, the radio quit working.
Your tube filament is most likely open. A 117Z3 can be replaced with a 1N4004 silicon diode and resistor in series. The band end of the diode connects to pin #6 of the 117Z3. The other end pin #5 through a resistor. 47 ohms, 1 or 2 watts, should be ok. I would go this way until the radio works. The diode is much lower cost than another tube.
Some tube testers can not supply the 117 volts required by this tube. You don't need a tester when a tube doesn't light.
Changing electrolytic filter caps isn't hard. Look up the schematic and buy replacement caps with slightly higher capacity and the same or greater voltage rating. The originals are usually a group of caps in a single unit. They can be replaced by individual caps. You do need to watch polarity. One lead will be positive, the other negative. Post here when you have questions.
Use a variac when powering up the radio. If you don't have one, wire a 40-60 watt light bulb in series with the radio. The light will act somewhat as a fuse.
: Norm,
: Thanks for the reply. In answer to your question, I don't think either of my testers are capable of testing the 117V tubes or at least I have no tube chart that has any listing starting with "117". I do have a cheapo "Fedro" tester that has just a neon light to signify whether or not there is an open in the tube and that tester says the tube is OK. As for the voltage that you mention, I will try to measure them, but the tube does not even light anymore so I don't know if it is possible.
: I think that you are right that it is a problem with the capacitor(s), but I have never attempted recapping a set as of yet.
: I have a copy of David Johnson's Book which makes it seem like not such a big deal to recap using caps of equal or greater value than those being replaced. However, I have read other articles which make it sound somewhat trickier. I am not afraid to try but I would like a little expert advice before recapping.
: Thanks,
: Paul
Norm,
: Thanks,
: Paul
