philco 46-1201-code127
8/26/2006 6:34:33 PMphil
this has the usual problem,no reception,already recapped. has a 50y6 as rec. instead of 35y4,i can't find any info on code 127,only 122,121. all voltages o.k. except pin4 on 7a8,its at neg1 instead of neg 12.5 and pin3 on 7b7 is at zero instead of 38. HELP!
lost in sacramento again,phil
8/26/2006 7:56:48 PMphil
:this has the usual problem,no reception,already recapped. has a 50y6 as rec. instead of 35y4,i can't find any info on code 127,only 122,121. all voltages o.k. except pin4 on 7a8,its at neg1 instead of neg 12.5 and pin3 on 7b7 is at zero instead of 38. HELP!
:lost in sacramento again,phil
never mind everyone,i found r10 open,replaced and it now works,thanks,phil
