Airline 93BR-720A
8/25/2006 8:01:35 PMTerry
This unit has a built in "loop wire" antenna. I have 1.6 ohms from #1 to #2 and opens on 1-3, 1-4, etc.
There are very light gauge wires along side of the heavier wires. I am using Rider page 11-36 but I can't pick out the detail.
Terry
8/26/2006 3:06:49 PMBill G.
:This unit has a built in "loop wire" antenna. I have 1.6 ohms from #1 to #2 and opens on 1-3, 1-4, etc.
:There are very light gauge wires along side of the heavier wires. I am using Rider page 11-36 but I can't pick out the detail.
:Terry
Hi Terry,
I have looked at the schematic and you should have connections on the loop, A to M, and F to B, with the later showing continuity to ground.
I don't recognize the #1, #2, #3, or #4 points you described.
Best Regards,
Bill Grimm
8/26/2006 9:59:19 PMTerry
::This unit has a built in "loop wire" antenna. I have 1.6 ohms from #1 to #2 and opens on 1-3, 1-4, etc.
::There are very light gauge wires along side of the heavier wires. I am using Rider page 11-36 but I can't pick out the detail.
::Terry
:Hi Terry,
: I have looked at the schematic and you should have connections on the loop, A to M, and F to B, with the later showing continuity to ground.
: I don't recognize the #1, #2, #3, or #4 points you described.
:Best Regards,
:Bill Grimm
I think I see what you mean. My #1 is the green (bottom of the page on Rider 11-36, #2 is the white, #3 is the brown, #4 is the yellow, so following what you say, then my #1 is green and B, #2 is white and F, #3 is brown and M and #4 is yellow and A.
There are no wires connected to M and A. Can I wind some and connect to the terminals? Sorry for this question,as it may seem silly. I do appeciate all of your help.
Terry
8/28/2006 10:54:32 AMBill G.
:::This unit has a built in "loop wire" antenna. I have 1.6 ohms from #1 to #2 and opens on 1-3, 1-4, etc.
:::There are very light gauge wires along side of the heavier wires. I am using Rider page 11-36 but I can't pick out the detail.
:::Terry
::Hi Terry,
:: I have looked at the schematic and you should have connections on the loop, A to M, and F to B, with the later showing continuity to ground.
:: I don't recognize the #1, #2, #3, or #4 points you described.
::Best Regards,
::Bill Grimm
:I think I see what you mean. My #1 is the green (bottom of the page on Rider 11-36, #2 is the white, #3 is the brown, #4 is the yellow, so following what you say, then my #1 is green and B, #2 is white and F, #3 is brown and M and #4 is yellow and A.
:There are no wires connected to M and A. Can I wind some and connect to the terminals? Sorry for this question,as it may seem silly. I do appeciate all of your help.
:Terry
Hi Terry,
I am a litttle confused. I thought you had figured that brown connected to M and yellow connected to A.
That is a very interesting set you have there. I have not seen a 35 volt filament winding on a transformer before! when you get this baby working, it will throw off some heat.
All the Best,
Bill G.
9/9/2006 8:18:16 PMTerry
::::This unit has a built in "loop wire" antenna. I have 1.6 ohms from #1 to #2 and opens on 1-3, 1-4, etc.
::::There are very light gauge wires along side of the heavier wires. I am using Rider page 11-36 but I can't pick out the detail.
::::Terry
:::Hi Terry,
::: I have looked at the schematic and you should have connections on the loop, A to M, and F to B, with the later showing continuity to ground.
::: I don't recognize the #1, #2, #3, or #4 points you described.
:::Best Regards,
:::Bill Grimm
::I think I see what you mean. My #1 is the green (bottom of the page on Rider 11-36, #2 is the white, #3 is the brown, #4 is the yellow, so following what you say, then my #1 is green and B, #2 is white and F, #3 is brown and M and #4 is yellow and A.
::There are no wires connected to M and A. Can I wind some and connect to the terminals? Sorry for this question,as it may seem silly. I do appeciate all of your help.
::Terry
:Hi Terry,
: I am a litttle confused. I thought you had figured that brown connected to M and yellow connected to A.
: That is a very interesting set you have there. I have not seen a 35 volt filament winding on a transformer before! when you get this baby working, it will throw off some heat.
:All the Best,
:Bill G.
Thank you for all of your help. The radio is working just fine.
Terry
