Tonfunk GMBH 20878312
8/19/2006 11:19:24 AMJD Wilder
I'm searching for schematic and any other information on this German SW Reciever has 5 TUBES that are missing. The following information is on the reciever.
Made in Western Germany
High Fidelity
On the tags in the back:
Gerate Typ: W2087
Gerate Nr: 20878312
( Kartan Nummer )
8/23/2006 4:49:50 PMNick
:I'm searching for schematic and any other information on this German SW Reciever has 5 TUBES that are missing. The following information is on the reciever.
:Made in Western Germany
:High Fidelity
:On the tags in the back:
:Tonfunk GMBH 20878312
:Gerate Typ: W2087
:Gerate Nr: 20878312
:( Kartan Nummer )
I've worked on a Tonfont 2087, it's a beautiful radio. There is a Sams Photofact folder available for W2086, a similar model, number 415-14. You can get this from michelletroutman.com or I have a poor copy which I can send you. Click on my name above and email your address. Nick
9/3/2006 6:21:02 AMJeff & Teresa
Nick, is the W2086 circuit layout the same as the W2087? Do you know what the tube layout is for the W2087? Several of them are missing in my unit.
Could you emailmail a copy of your manual?
Thankyou so much
Jeff & Teresa
::I'm searching for schematic and any other information on this German SW Reciever has 5 TUBES that are missing. The following information is on the reciever.
::Made in Western Germany
::High Fidelity
::On the tags in the back:
::Tonfunk GMBH 20878312
::Gerate Typ: W2087
::Gerate Nr: 20878312
::( Kartan Nummer )
:I've worked on a Tonfont 2087, it's a beautiful radio. There is a Sams Photofact folder available for W2086, a similar model, number 415-14. You can get this from michelletroutman.com or I have a poor copy which I can send you. Click on my name above and email your address. Nick
3/12/2007 9:26:06 PMJeff
March 12, 2007
Nick, Do you know SAMs model number for the Tonfunk W2087??
Jeff
::High Fidelity
::Gerate Typ: W2087
::( Kartan Nummer )
3/13/2007 8:38:08 PMNick S
:March 12, 2007
:Nick, Do you know SAMs model number for the Tonfunk W2087??
:Jeff
:The Sams Photofact folder for Mod W2086 is 415-14. It is similar to the W2087. The tube lineup is: EL84 (6BQ5) output, EABC80 (6T8) AM det/AF Amp FM det, EF89 Am/Fm IF amps, ECH81 (6AJ8) AM FM IF amp/AM mixer, ECC85 (6AQ8) FM conv/RF amp, EM80 indicator tube. Nick
:::I'm searching for schematic and any other information on this German SW Reciever has 5 TUBES that are missing. The following information is on the reciever.
:::Made in Western Germany
:::High Fidelity
:::On the tags in the back:
:::Tonfunk GMBH 20878312
:::Gerate Typ: W2087
:::Gerate Nr: 20878312
:::( Kartan Nummer )
::I've worked on a Tonfont 2087, it's a beautiful radio. There is a Sams Photofact folder available for W2086, a similar model, number 415-14. You can get this from michelletroutman.com or I have a poor copy which I can send you. Click on my name above and email your address. Nick
3/13/2007 9:24:29 PMEdd
Looking at the posting dates ....there has been some time lag of a half a year..gathering dust...but with the latest / current posting dates query in ind.....I submit:
With that healthy 6 in woofer-spkr along with that cluster of electrostata-mo-cized speakers ....it should really sound crisp.....Wannna buy some toobs...cheeep ?
Tech ref:
http://img267.imageshack.us/img267/6027/tonefunked2kqg3.jpg
(Beeeeeg / enlarged J-pegster ...so right click and then MAG it on up.)
